Re: Which Kit??
Posted: Fri Jul 31, 2015 11:33 am
It's the age of equality. The small carb users are now allowed to marry each other too.DaleUK wrote:Why do some say use a 26mm card and some say 30mm??
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
both with kits and carbs you need to ask the question "how do i want my scooter to feel?" if you like the feel of a standard scooter but find it under powered then the mugello, gt186, rt190 with a 24-30mm carb breth sweet filter and bgm clubman will tick the boxes.DaleUK wrote:Why do some say use a 26mm card and some say 30mm??
Exactly: A decent tune to the cylinder + decent piston + re-jet and the requirements are met for arround £100LI225Canada wrote:I have been trying to find the article/topic/link which I read a few months ago now, but the lads here at Scooterotica had a post explaining how they can port up a 150 cylinder with very empressive results.
May want to give them a call for some advice.
Just another option to consider.
all that for £100? including a decent piston? have you just woke up after going to bed in 1989?Yanker wrote:Exactly: A decent tune to the cylinder + decent piston + re-jet and the requirements are met for arround £100LI225Canada wrote:I have been trying to find the article/topic/link which I read a few months ago now, but the lads here at Scooterotica had a post explaining how they can port up a 150 cylinder with very empressive results.
No, I woke up today. A Mahle Piston: £40, conversion re-bore £30 re-jet £10, then match the cc ports and alter the inlet + exhaust ports: All in for £80 actually. Are you mathematically as well as phonetically challenged?eden wrote:all that for £100? including a decent piston? have you just woke up after going to bed in 1989?Yanker wrote:Exactly: A decent tune to the cylinder + decent piston + re-jet and the requirements are met for arround £100LI225Canada wrote:I have been trying to find the article/topic/link which I read a few months ago now, but the lads here at Scooterotica had a post explaining how they can port up a 150 cylinder with very empressive results.
Just another option to consider.![]()
