Re: Well, won't be buying from Willenhall Scooters again!
Posted: Sun May 17, 2015 8:43 pm
What I don't understand is how the shim affects the seal ?
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
Not quite, that would be a whole inch missing,Donnie wrote:Not this part, this is supposed to be a 1mm spacer washer, therefore should be 1mm or near as damn it surely. Some parts like you say need a fettle granted, but to produce and sell something like this is frankly either stupid or lazy. It's akin to a 3.50 x 10 tyre being produced which actually turns out to be 3.50 x 9. :-/
Donnie has one of the seal retaining plates:eden wrote:This what you are referring too?
click the pic to see the ebay listing, £2.80 looks nice and cheap to methe cone alone is £13 from MB lol
if so all the shim does is keep the cone off the bearing, they are very thin.
Does the one you received look like the one in the picture
This plate keeps the seal in place!
Yep, this is what I got but as I say the shim was near paper thin as opposed to proper metal if you see what i mean.
Basically, the way it was stamped has left a sharp lip which is in contact with the rubber seal right on the outside edge, not much but enough that Id worry about it rubbing and fecking the seal again.wack 63 wrote:What I don't understand is how the shim affects the seal ?
