Re: fitting a fuel pump to stock fitting carb
Posted: Sun Mar 22, 2015 4:29 pm
the 26mm E is for p2 - not suitable for a T5
Pinasco do a "racing" version for T5 - SI 2/26 GR
All the fuel lines are enlarged and it has a cosa size needle 5.2
Ive not heard a good word about the bowl extension
going down the vacuum fuel pump route involves drilling and tapping the casings at the rear to insert connection point - its engine out and casings apart
ive done a few malossi 172 and never had fuelling issues - both using a standard piaggio tap and a spaco 24mm
look to the easy wins first as people have already advised
