Page 4 of 6
Re: brass exhaust nuts
Posted: Mon Jan 05, 2015 12:34 am
by PeteB
Please ignore above comment from me. I completely bolloxed it up and don't know how to delete...
Posted: Thu Jan 08, 2015 5:54 am
by badwrench
My understanding is that they used brass nuts (a lot of cars use brass nuts on the exhaust as well) because brass expands a lot with very little heat so the nuts tend to lock themselves on to a running motor as it warms up.
Posted: Thu Jan 08, 2015 7:26 pm
by joespeed
so which way is correct?
Posted: Thu Jan 08, 2015 7:34 pm
by bolzenanker
Put them on anyway you like, if they fall off you got it wrong!
Personally, spring washer then round side of nut against the washer.
Posted: Thu Jan 08, 2015 10:06 pm
by sunrisemac
round side down, there is no point in having a machined diameter on the top of the nut, if it is on the bottom it ensures the hexagon cant catch on welds, we use similar nuts on race car exhaust flanges for that reason
Posted: Thu Jan 08, 2015 10:12 pm
by lambro
sunrisemac wrote:round side down, there is no point in having a machined diameter on the top of the nut, if it is on the bottom it ensures the hexagon cant catch on welds, we use similar nuts on race car exhaust flanges for that reason
Aren't you more likely to have a proud weld where the flange is welded to the downpipe, therefore it would make sense to have the round bit upwards.
With a spring washer and a flat washer between its round bit and the flange of course.
Posted: Thu Jan 08, 2015 11:05 pm
by bristolmod
I think we may be getting "Up" and "Down" confused now.......
Rounded bit next to exhaust flange.
Posted: Thu Jan 08, 2015 11:13 pm
by philz
The round end of the nut has a larger surface area to place pressure and contact on the flange. If used the other way what is the purpose of the rounded end? It may not be there.
Posted: Fri Jan 09, 2015 11:59 pm
by sunrisemac
here's a sketch of what I mean
Posted: Sat Jan 10, 2015 12:04 am
by lambro
sunrisemac wrote:here's a sketch of what I mean
Same as me, but my exhaust bolts the other way up
