Page 4 of 9
Re: Delving into VSE1M
Posted: Sat Feb 07, 2015 3:25 pm
by storkfoot
Yes, the cam came off with a very gentle tap although the bearing, as usual, took a bit more persuading.
I'd been trying to persuade myself that the big end bearing was probably fine. But, I've failed to convince myself and so I've bitten the bullet and taken the crank in for a new conrod, shims and big end bearing to be fitted. Incidentally, Baz, yes you are right. The pin is the same size as on a P range crank.
Posted: Sat Feb 07, 2015 5:52 pm
by gaz_powell
wise move - complete piece of mind
Posted: Sat Feb 07, 2015 7:42 pm
by bazman
Yeah might as well go the full hog so to speak mate
Posted: Sat Feb 07, 2015 8:37 pm
by storkfoot
It's a typical engine build. You open up an engine to replace a few springs then you keep reaching for the credit card time and time again
Posted: Sun Feb 08, 2015 3:44 pm
by cgt75b
storkfoot wrote:It's a typical engine build. You open up an engine to replace a few springs then you keep reaching for the credit card time and time again
I its a never ending circle of spending money lol. Are you going to tweak the top end at all ?
Posted: Sun Feb 08, 2015 5:31 pm
by storkfoot
No, de coke and new rings. I love the feel of the Rally in that it produces reasonable power but is so unstressed. I wouldn't want to lose that. I may even put the original exhaust back on rather than the Sito Plus I have been running.
Posted: Mon Feb 09, 2015 10:24 pm
by gaz_powell
Go SIP road - better than sito plus - improved performance with original looks and a slightly meatier standard sound.
Early indications on my change to SIP road are good but not done any hard motorway work to compare against the SIP performer i had been using.
Posted: Tue Feb 10, 2015 11:10 am
by cartmel808
gaz_powell wrote:Go SIP road - better than sito plus - improved performance with original looks and a slightly meatier standard sound.
+1 ^... got the Sip 2 pipe on my Rally - initially upped the main jet to 122, but have since dropped down to 120 main - which now seems spot-on... this along with the stiffer front spring & bgm pro damper are the best upgrades you can make to a standard Rally 200
Posted: Tue Feb 10, 2015 12:21 pm
by weeks
cartmel808 wrote:gaz_powell wrote:Go SIP road - better than sito plus - improved performance with original looks and a slightly meatier standard sound.
Sorry to hijack your engine re-build thread Paul
......................... Interested to know if the stiffer front spring makes a noticeable difference, that and the performance of the BGM pro ?
Posted: Tue Feb 10, 2015 2:39 pm
by cartmel808
Definitely made a big improvement to mine over the standard spring & damper...
Rally front ends are notorious for diving badly under braking & on the standard set-up mine was terrible... plus the front end would bottom out really easily just under normal riding conditions.
Fitting a 33% stiffer front spring & BGM Pro damper has made a massive improvement over how it was... front end travel is now much more controlled when braking, giving better front brake performance - plus I've never had it bottom out yet since doing the conversion - just better all round ride & handling...
