T5 aly with a 152 polini conversion.
jackson85
Main scooter: T5mk1
Fecking T5 and the chocolate casings
fastfrog
A blo.dy crystal glass....
Size matters!
johnd
Main scooter: 1970 Dl125
I think Oz who has a TS1 on T5 casings has strengthened that area with and extra bolt on the clutch cover. one either side of the primary axle, for more strength. An idea?
fastfrog
I've seen this transformation. Very nice job. Anyway casing is too thin at this very place. It needs to be almost doubled to insure more strengh.
Size matters!
Fruitjuice
Question is how deep the recess is inside the primary gearstack...
Find somebody with a lathe that can turn you a new longer primary shaft.The cylindrical bit going through the casing would need to be about 1,5 to 2 inches longer.
Shouldn' be too difficult, it's not a hardened shaft. Don't worry about the keyway in the threads.
Weld a pre-drilled piece of aluminium (same diameter as the existing hole) to the casing next to the existing primary shaft hole and it'll never break again. You wouldn't even need to fix the existing crack.
Then just put a grub screw through the top of the aluminium bit to keep the shaft from rotating.
You could even go as far as to make a small chamfer at the end of the aluminium bit and fit a small O-ring to seal it all.
fastfrog
Quite difficult I guess. People usually just weld and fix the crack (hum hum don't misunderstand me!)
Size matters!
OzOAP
Main scooter: Vespa PTS1E
ducksta
i do like that anybody offering to do one for me if i send the clutch housing
ducksta wrote:i do like that anybody offering to do one for me if i send the clutch housing
you would obviously need to do the main casing at the same time dont forget ! lol
fastfrog
Size matters!
