I've been resistant to the temptations of the outboard style of brake for a number of reasons. Firstly I've heard a lot say that the size of the disc and caliper on a lot of the conversions are too big for the Lambretta and this can make it snatchy. Secondly, looks, I love the look of the original disc hub on the front and wouldn't consider the popular ones that uses drum hub. I could just about entertain the pepperpot style but again I think these use the same disc and caliper as the others. The PM ones use a smaller disc and a Piaggio caliper which i think is more suited to the Lambretta, but are a shade above my budget at present. The ideal one would be the LTH with the old style disc side but still out of my price range at the moment
Latterly I'm starting to consider it as an option but not by the conventional route. A while back I'd bought what was advertised as a PM wheel without the caliper or carrier.
On consulting PM they said that it wasn't one of their wheels but was in fact out of a Zip. They advised that this is the wheel that they use for their conversion but they machine it to fit with their caliper carrier and speedo drive. They weren't prepared to supply any parts for me to do my own conversion either because of their branding on the parts.
I've trial fitted this in the forks using a standard Lambretta disc style axle and it looks like it should fit without a great deal of trouble.
However in the interests of moving things along I decide that the effort involved is too much for now and decide to push on with the Taffspeed converted inboard backplate. I've still got a couple of problems to overcome though as it's not complete. The piston is missing from the slave and the bleed screw is also missing.
I've had this blasted and coated and now the slave won't screw fully home. Its short by about two turns.
I think that this is further damage caused by careless blasting. It takes several hours of work with a thread file and a 1.5 pitch tap to get this all the way home. With it screwing in smoothly I also have to remove the coating from the top lip to get the bleed nipple in the right place i.e. near the top.
Meanwhile after a post on here Ian advised that if this indeed was one of their conversions then the piston should be out of a Mini Metro four pot caliper. A bit of research and trawling the Mini forums uncovers the right part if anyone else interested in this I sourced a seal repair kit and piston from minispares.com
Part numbers -
Piston - SAAS1022
Seal kit - GRK5003
The next issue is to source a long enough M7 x 1.00 mm bleed nipple. I eventually find a suitable one on ebay and fit it and the new seals.
However whatever I do I can't get the blooming piston in. Take the seals out and it drops right in with the seals in I cannot get it in at all. Every time I try it coggles to one side or the other and will not go in straight. Someone suggests a little red rubber grease but that doesn't help. Eventually after stopping to think about it I realise I need something to push it in straight and hit on the idea of using a G clamp.
That does it and it slides in with surprisingly little effort.
I strip out the disc brake and change over the backplates, connect up the hose and bleed it off.
and with it bled we have a much better feeling brake
Unfortunately I cannot get the speedo drive to work with this backplate the worm drive simply won't turn. I've had it back to bits a couple of times to see if I can improve it but nothing seems to work.
