Page 4 of 9
Re: Taffy copy pipe
Posted: Sat Mar 22, 2014 6:07 pm
by camel
I don't know..I know some muggys do and I've machined mine back.it looks as if the stub and header pipe are not fully home as to not allow the expansion to sit in the correct place for the bracket
Re: Taffy copy pipe
Posted: Sat Mar 22, 2014 7:19 pm
by CPH Lambretta
I had exactly this problem trying to fit a JL3 to a V4 mugello.
Nothing lined up because the exhaust gasket face is around 10mm further away from the piston skirt on the mugello than standard :evil:
Great design feature :?
Re: Taffy copy pipe
Posted: Sat Mar 22, 2014 7:50 pm
by joespeed
so how did you cure the problem?
Re: Taffy copy pipe
Posted: Sat Mar 22, 2014 8:54 pm
by simonwwfc
camel wrote:Is it about 10mm out?is it a mugello top end?
So does having Muggelo kits make it also a issue ?
Re: Taffy copy pipe
by simonwwfc
Here's mine now
Re: Taffy copy pipe
Posted: Sat Mar 22, 2014 9:13 pm
by joespeed
the pipe is very low at the front,when riding two up it will ground very easy!
i know this is a new pipe but you will have to alter it .
i think the short boards are not right on this scooter!
Re: Taffy copy pipe
Posted: Sat Mar 22, 2014 10:37 pm
by camel
Some mugello kits have a thicker exhaust gasket face making some pipes hard to fit,I know initially the ads range of pipes offered a specific mugello stub,I think the mb clubman has a specific stub too.I measured the difference on my 225 mugello and it was 7mm thicker,I machined my gasket face to make all pipes fit.
Re: Taffy copy pipe
Posted: Sat Mar 22, 2014 10:48 pm
by boris
shocky wrote:
Chris-47 wrote:No it's the bgm 195 kit
Does the gasket face of the exhaust project further out the barrel on these kits ?
Your probably right I'll check in the morning.
I hate my RT kit wish I had never read the wright up on it.
Sent from my HTC Sensation Z710e using Tapatalk
Re: Taffy copy pipe
Posted: Sat Mar 22, 2014 11:07 pm
by camel
simonwwfc wrote:Here's mine now
This certainly doesn't look correct,I'd disconnect the tailcan bracket,slacken all your mounting bolts off,allow the pipe to find its natural position and tighten up,totally leaving the can bracket for now as it looks set far too high,then adjust the can bracket to suit its natural position.I actually made my own bracket coming from the shock mount as it looks so naf
Re: Taffy copy pipe
Posted: Sun Mar 23, 2014 8:12 am
by CPH Lambretta
joespeed wrote:so how did you cure the problem?
I had to use a different sharksfin bracket that was slotted downwards so the whole pipe sat slightly lower at the front, but it still came higher at the back so I had to extend the bracket at the back upwards.
I was generally very disappointed with the Mugello kit, the ports were all over the place and the exhaust port design just made the whole thing a ballache :x
