Page 4 of 4
Re: Quattrini Build....
Posted: Sat Jan 03, 2015 11:38 pm
by cartmel808
Just pulling yer leg about the crank & carb Sean
... will hopefully be down next week with another pipe to try out on it though.
Posted: Mon Jan 05, 2015 5:48 pm
by sean brady scooters
ok graham ,you had me going there as i thought you were serious ...lol
Posted: Sat Jan 10, 2015 4:13 pm
well this should be interesting as graham has just delivered a quattrini pipe today ,so old pipe off and new one on and to re dyno ..
and while they were both off I did a quick check to measure the difference in tuned length between them both ,the new quattrini pipe is roughly 5 inches shorter !
and therefore ,following the "rough,n,ready " rule that for every 1 inch shorter on tuned length it elavates peak power by 500rpm this should mean that it could possibly make peak power now at 8500 rpm plus instead of the 6000 rpm on the old pipe ..
but we shall soon see
Posted: Mon Jan 12, 2015 12:24 pm
by cartmel808
sean brady scooters wrote:well this should be interesting as graham has just delivered a quattrini pipe today ,so old pipe off and new one on and to re dyno ..
Nice one Sean - should do the trick!... I forgot to check when I dropped the pipe off on Saturday - will I be able to retain the centre stand with the quattrini exhaust, or will it now require a side stand fitting?
Posted: Mon Jan 12, 2015 8:38 pm
well graham ,now that i have found some bolts that were omitted from the fixing kit and swapped the springs provided for some shorter ones it fits very well and doesnt foul on the stand at all ...
Posted: Tue Jan 13, 2015 7:33 pm
dan is here tomoz and is gonna dyno it ,and no doubt post up the results
Posted: Wed Jan 14, 2015 12:02 am
by cartmel808
sean brady scooters wrote:well graham ,now that i have found some bolts that were omitted from the fixing kit and swapped the springs provided for some shorter ones it fits very well and doesnt foul on the stand at all ...
Another nice straight forward job then Sean
.... seems like most of the stuff I bring you lately is either missing some of its hardware, or is just not fit for purpose.... it's not intentional mate - honest
Posted: Fri Jan 16, 2015 9:31 pm
by hobospeed
Hey, check out BGM's new Big Box Sport pipe. It's the street racer/non touring version of their Big Box pipe. They tested it on a LML reed motor with an 24mm Si carb and a unmodified Quattrini running a 60 mm crank. Seems like a pretty good match with this kit, other than the mild dip in torque around 5500 rpm.
Red is the Quattrini and blue is a Polini 177:
The write up is only in German for now but you can through it through a translator to get most of the info:
http://blog.scooter-center.com/vespa-au ... box-sport/
Posted: Wed Aug 17, 2016 9:25 am
by drunkmunkey6969
Topic moved
