Re: RB20 fitment issues.
Posted: Sat Nov 16, 2013 8:33 pm
Mark, I'm not here to slate dealers but I'm quite happy to point out simple engineering reasons for some products giving problems in use. The bigger the diameter of the stud, the more likely that people will run into clearance/alignment issues. I don't know the diameters of all the studs out there BUT the bigger the stud the bigger the problem.
If I did start to name and shame dealers or products then the thread would quickly be pulled by moderators anyway, which doesn't help anyone.
You would be pretty pissed off if I came on here and started slagging off MB products, which I have not (I don't have your studs so cannot, and have not, named them). In the same light, others would have the same right to be pretty pissed off if I did start naming and shaming their product, without first hand experience of the product that I was having a go at.
There are times that I will quite openly name a product that I've first hand experience of having problems with, so that others can avoid paying for the same problems. However, I'm not talking specific dealers/products here, rather, I am point out the simple issue behind many (yes, many) people running into issues with increased stud diameters. Yes, these issues are much more likely to become evident with certain kits, I've never suggested otherwise, yet in those cases the kit can take 50% of the blame and the fat stud should take the other 50%, rather than the common response of taking 0% blame and pass on 100% to someone else.
I have no doubt that you already know which kits are most likely to give issues with 'fat' studs so why don't you name them? That's not exactly fair though as these same kits fit fine with standard shaft diameter studs, so there isn't an issue unless 'fat' studs are introduced to the assembly. Ian was quite right when he wrote of thinking of a motor as an assembly and the more that we know about what fits (or doesn't) with what, the better for all of us.
What is important about this issue is that it is raised and brought to the attention of the masses, NOT TO APPORTION BLAME, but to help people identify a common problem that they might be facing and give them good advice that rectifies the problem, avoids damage, and (worst case) avoids danger/accidents. I'm very happy to help others and my first hand experience of this issue qualifies me to inform others of it.
Cheers to you all (that'll be me sitting on the fence again) and enjoy the weekend.
Edit: Please note that I've not mentioned 'straight' once. Straight has nothing to do with this, diameter is what we're talking about here. I'd hope that any manufacturer could make a straight stud, even if they struggle with getting the diameter right.
