Page 4 of 5
Re: LD ish
Posted: Sun Aug 09, 2015 9:30 pm
by GLscoot
http://www.ebay.co.uk/itm/281763054764? ... EBIDX%3AIT
what about this for your oil, a little expensive but I think they look good, have you thought about using acf50 just to give the body work a little more protection. nice work & excellent looking scooter.
Re: LD ish
Posted: Mon Aug 10, 2015 7:00 pm
by gerryjunior
thanks , but that tin is far too new looking for this scoot, no ac50, this one was genuinely pulled out of a hedge , ill just leave it aged as is :D
Re: LD ish
Posted: Sat Aug 22, 2015 5:09 pm
by gerryjunior
i welded a simple bracket bent around the shape of the dampers to the fork leg ,for the anti dive, it works a treat,,
Re: LD ish
Posted: Sat Aug 22, 2015 5:13 pm
by gerryjunior
ive also fitted some led indicators for safety,
Re: LD ish
Posted: Sat Aug 22, 2015 8:56 pm
by jason frost
gerryjunior wrote:i welded a simple bracket bent around the shape of the dampers to the fork leg ,for the anti dive, it works a treat,,
Have you removed the peg from the link ?
Re: LD ish
Posted: Sat Aug 22, 2015 10:18 pm
by gerryjunior
haven't removed anything from the link.
Re: LD ish
Posted: Wed Aug 26, 2015 11:18 pm
by gerryjunior
im building a new engine for this , a casa ss225 ,kit no 29 , lth clutch ,li 150 gearbox, 58 mil crank, carb and exhaust to be decided..
Re: LD ish
Posted: Sun Aug 30, 2015 12:34 am
by wrecklessrobbie
Gerry
Are you running a battery on this scooter?
How have you wired the indicators.
I am looking to fit indicators on my series 2. I am not planning on using a battery, I was hoping to use a relay on ac...similar to the early p200 set up.
Do you have a wiring diagram. I will be using a AF electronic wiring loom but will add more wires.
Thank you
Robbie
Re: LD ish
Posted: Sun Aug 30, 2015 7:57 am
by gerryjunior
yes im running them through a battery .
Re: LD ish
Posted: Sun Aug 30, 2015 8:08 pm
by jason frost
gerryjunior wrote:haven't removed anything from the link.
So I take it that the caliper plate is not connected to the link ?
