thanks, Im nothing more special than all the other guys out there that knock up stuff in the garage.
I do have the ability to visualise things very easily, I apply a lot of logic and fore thought to my builds, this one for example, I had everything planned and worked out as far as the paintjob, well before I even cut the first bits of steel.
the radiator is going under the floor in a bellypan style affair, have a nice push fan to help keep things cool, will do a nice sheet metal curved top inside the bellypan to push the air down and through the rad, if cooling isn't an issue then I will holesaw a couple of holes in the back to let air bleedout as I am a little concerned what it might do to the handling
Im on stupid small budgets, so things take a long while, and the upshot of this is that I have learnt to do lots of things myself,Im far from a master of all skills,but I can do enough to get by
perfect example is the exhaust,I know that they are expensive to be made, messing with a 2 stroke expansion is silly, so I mocked up the engine with pipe fitted, then built the swingarm assembly around it, all I had to do was measure the stinger, cut it off, make a new one the same length and I have a very good expansion system, that performs as it was designed to do, fits perfectly, and all for just a few quid
the chamber fits like it did on the bike, ground clearance is small about 3.25", that's a problem, but I have made sure that the issues are on the centreline of the chassis, so cornering isn't an issue, and the suspension travel wont allow it to bottom, just have to watch for kerbs and speed bumps.
tonights mission was to gather together all the electronic boxes and servo etc,I dont have a loom or ignition barrel, no point buying them as I wont use them, why waste money.
with some patch leads and odds/ends of wire I soon had the servo making that addictive whirring noise and then a flurry of sparks at the plug, well pleased.
hopefully this weekend I will rig up a test fuel tank and get her running
