Page 4 of 4
Re: Piston to bore clearance
Posted: Wed Apr 17, 2013 2:13 pm
by soosh
Adam_Winstone wrote:^... not like your next ride was going to be a biggie though :shock: (Milan 97)
Thats what was doing my head in,2000ml trip planned and this thing was rattling like mad and was told its fine by them!! :shock:
Just meant after that rebore i had to get some miles on it quick before the off. Was good doing the rebuild in the kitchen,good old days when you could do that.That trip was absolutely fantastic!! :D
Posted: Wed Apr 17, 2013 6:41 pm
by Adam_Winstone
Good times :)
Posted: Sat May 11, 2013 6:55 pm
by a.j
I've suffered from heat seizures for feckin' years. My carb has been set up perfectly. Examples; on this b/h Monday I took a 25 mile motorway ride in glorious sunshine and warm weather and it ran like a dream.
Today I got on the motorway in colder temperatures and nipped up after four miles!
Work that one out! :-(
Posted: Sat May 11, 2013 8:37 pm
by bristolmod
what piston is in there?
Posted: Sat May 11, 2013 10:26 pm
by Grumpy225
a.j wrote:I've suffered from heat seizures for feckin' years. My carb has been set up perfectly. Examples; on this b/h Monday I took a 25 mile motorway ride in glorious sunshine and warm weather and it ran like a dream.
Cold air=dense air=more air=lean condition=sieze
For me, I like to jet a bike when it's around 70f, this way when the weather cools down or warms up the jetting won't be too far off from where I started and extreme changes in the weather can be handled by a mix adjustment on the carb.
Posted: Sat May 11, 2013 11:18 pm
by soosh
That's a f@@ker then if you get a new carb for Christmas.
Posted: Sun May 12, 2013 3:13 am
by Muttley McLadd
soosh wrote: That's a f@@ker then if you get yourself a new carb for Christmas.
Fixed ;)
Posted: Sun May 12, 2013 1:43 pm
by nelson pk
Yep, cold air will cause a leaner condition. A road going scooter should be jetted with enough margin for error in my opinion. For example, it will run rich with slighty less performance on a hot day and run better on a cool day but not too lean. If you have and adjustable power jet and EGT or CHT you can adjust jetting easily to suit conditions for better performance.
Posted: Sun May 12, 2013 5:32 pm
by a.j
Same conditions as yesterday, took it out for a few miles thrashing with fingers over the clutch & it ran really well. Doing me nut in!
