Page 4 of 6
Re: 12volt DC Mod charger
Posted: Sun May 12, 2013 2:08 pm
by shep
Cheers, maybe not then.
Posted: Sun May 12, 2013 5:30 pm
by a.j
I connected mine up this afty..works a treat.
Posted: Fri Jun 13, 2014 10:09 pm
by Timbo
Any pics of where you've put the end that connects to the sat nav?
Posted: Sat Jun 14, 2014 7:31 pm
by lammydave
used this for my sat nav and phone on a recent trip to france....well worth the dosh!
Posted: Sat Jun 14, 2014 9:50 pm
by Timbo
Have ordered one and seen the installation vid, but just wanting to know how peeps fit it near the handle bars..
Posted: Sun Jun 15, 2014 6:07 pm
by a.j
Timbo wrote:Have ordered one and seen the installation vid, but just wanting to know how peeps fit it near the handle bars..
I put mine under the seat. Absolutley mullered it. Can you get spares for it? I need the charging socket.
Posted: Sun Jun 15, 2014 7:56 pm
by ktmh5
If you don't use your airbox, bring it up through the scoop and it's protected from being crushed by the seat in there. I charged my phone up all the way back from Kelso. Placed it in a padded camera bag over the petrol flap where there is more room, worked a treat.
Rich'
Posted: Sun Jun 15, 2014 8:16 pm
by Timbo
No air box but I want it closer to the head set to run a sat nav..
Posted: Mon Jun 16, 2014 8:41 am
by Train Driver
Timbo wrote:No air box but I want it closer to the head set to run a sat nav..
Follow your wiring harness then get a plate made and fit it to your spare wheel carrier
Posted: Mon Jun 16, 2014 11:46 pm
by Bert Oni
I've got em on my GP & S2 and they're both fitted by siting the charger end on the lhs rear footboard support pretty near the regulator, with the length of cable following the frame loop passing under the tank along with the wiring loom, under the leggies and behind the horn casting. I then drilled a 10mm hole (& fitted rubber gromet) in the part of the leggies right next to the fork stem that won't be seen from the front as it's covered by the horn casting, for the cig lighter end to come out inside the legshield toolbox. Then slacken the 2 nuts securing the leggie toolbox slightly and push the 'flying' sat Nav lead behind the toolbox rubber in the corner.
Don't forget to feed the Mod charger cable from inside the toolbox though as obviously the cig lighter end won't pass through a 10mm hole ;) . This is all assuming that you have a legshield toolbox of course, although the same route can be used if you have an inside legshield spare wheel. The cable is just the right length, and they work a treat. Hope this helps Timbo.
