Re: Halogen Headlamp
Posted: Fri Mar 22, 2013 6:14 pm
All very well but whos fitted them and used them through a standard headlight lens? and what were the results
I know what you're saying Col, the LED's can be bright but ineffective. I have used them at night and the do the job by flooding-lighting the whole space in front of you. There is not a beam, despite the appearance of the refector. The very nature of the light generated by an LED makes it difficult to focus. However, you have got to remember where we have come from. There was never enough light with a 35/35 incandescent lamp, and I didn't find a 55/60w halogen a very effective (especially in a GP headlight, which is a rubbish shape for a reflector).coaster wrote:How does the light perform at night down those Suffolk and Essex lanes, that's the acid test I think? Someone (maybe on here) was raving about led lamps fitted in his spots. I bought a pair of 50 watt equivalents and fitted one in a pair of 4" spots. Although very bright, the light was very diffused and nowhere near as good as the 35 watt halogen in the other one. Your spots seem to have a reflector behind them which must focus the beam?
As above Donnie.Donnie wrote:All very well but who’s fitted them and used them through a standard headlight lens? and what were the results
If you're still doing the C2C I'll maybe get a look at how they look in the dark?Knowledge wrote:I have used them at night and the do the job by flooding-lighting the whole space in front of you. There is not a beam, despite the appearance of the refector
. You will notice that the fixings do without the screw and square nut configeration on the original version. You just screw the supplied bolts through and it catches in the fixings which give you loads of options for adjustment. Very pleased with my purchase and it is very bright.
