Page 4 of 5
Re: Running in tips
Posted: Sun Feb 24, 2013 11:17 pm
by victor
soosh wrote:
victor wrote:From the gigantic SIP catalogue:
SIP wrote:The aim of the running in period is for the relevant engine parts to integrate themselves and not for all contact surfaces to even each other out through a process of polishing as is the commonly held misbelief surrounding new cylinder parts. The recommended running in time is actually about 1 hour and not 1500km (1000mls) as some people mistakenly believe.
Dont think there will be a method that everyone will agree on that is "the way". My way has been laughed at before but have proven many times its reliable and works but you will have others who will do 700 odd miles on differnt jetting,different oils to carry out this process and they swear by it.Who is wrong and who is right? Maybe that way is for people who have sod all else to do as it can take forever!
But it must be possible to answer whether or not it is for the parts to integrate themselves or whether it's for the contact surfaces to even each other out through a process of polishing...?
Re: Running in tips
Posted: Mon Feb 25, 2013 12:13 am
by soosh
Maybe someone can come up with some proper scientific proof.
There's bound to be someone who's read a book on it.
If its a band new motor,its good to take it easy for the 1st couple of miles anyway,just listen to the motor.Just in case you didn't tighten up something that should of been tightened up quite tight.
Re: Running in tips
Posted: Mon Feb 25, 2013 9:07 am
by Muttley McLadd
soosh wrote:There's bound to be someone who's read a book on it.
Waiting for Nelson..
Re: Running in tips
Posted: Mon Feb 25, 2013 9:18 am
by ArmandTanzarian
If Nicasil is so good and doesn't need much running in, can someone explain why the recomended period for the avanti kit is so long?
From the instructions:
"Always use good quality synthetic oil, whilst running in use at 4% for the first 500 miles,
thereafter this may be dropped to 3%. Use an NGK B8ES spark plug or equivalent whilst running
in then maybe changed if necessary to a B9ES
Running in
First 200 miles stay below 45 mph and vary the speed (RPM)
Next 200 miles stay below 55 mph and vary the speed (RPM)
Next 100 miles stay below 65 mph and vary the speed (RPM)
For the next 250 miles keep varying the speed whilst gradually increasing the speed, do not hold at
maximum speed for any length of time. Do not hold at maximum speed until you have done at
least 750 miles.
Extra care must be taken whilst running in if you are running into a head wind or going up hill, slow down
and use a lower gear if necessary, the engine must not labour in any conditions."
Re: Running in tips
Posted: Mon Feb 25, 2013 9:23 am
by servetakid
Isnt it to do with the exhaust port being bridged?
Re: Running in tips
Posted: Mon Feb 25, 2013 11:05 am
by victor
ArmandTanzarian wrote:If Nicasil is so good and doesn't need much running in, can someone explain why the recomended period for the avanti kit is so long?
Is the Avanti nicasil lined? THought it was cast iron only...
Anyway, am curious of the same. There is no question that Ron who is making the kit is very knowledgeable (to say the least) and that the kit performs very well indeed, so why the rigorous running in process...?
Re: Running in tips
Posted: Mon Feb 25, 2013 2:13 pm
by rosscla
I thought it was more to do with the piston than the barrel
Re: Running in tips
Posted: Mon Feb 25, 2013 3:59 pm
by ove
servetakid wrote:Isnt it to do with the exhaust port being bridged?
As Jordan said its in because the exhaust port is a bridged one.
Re: Running in tips
Posted: Mon Feb 25, 2013 4:04 pm
by victor
The reason why you bridge an exhaust port is to avoid the piston rings from popping out as you maximise the port's width, and to minimize piston ring wear.
Shouldn't really affect running in from my point of view...
Re: Running in tips
Posted: Mon Feb 25, 2013 4:40 pm
by corrado
soosh wrote:Maybe someone can come up with some proper scientific proof.
I think you'll find that books were phased out in the noughties [fecking hate that word] and replaced by scientifically accurate forums in the process. I read it on Wickipaedophelia.
