Rotax 300 builld
TED CRUD
Looking Good :)
Smash Ya Pastie
Washington Posse s.c
RManson
Got the radiator sorted out, mounted and ready to go. Fan works great and will wire in using the stock thermostatic switch to prevent it from running needlessly.
ImageRotax Lamby build-021 by PotvinV8, on Flickr
Welded a couple of tabs on the leggies that accept a one-off aluminum bracket, top and bottom...
ImageRotax Lamby build-020 by PotvinV8, on Flickr
Also cut a pair of vents in the legshield under the mudguard so as to not upset too much of the original aesthetic. These will get covered in some sort of perforated metal when it's all said and done.
ImageRotax Lamby build-022 by PotvinV8, on Flickr
Next up is to mount the clocks, switch, etc. and perhaps fab up the exhaust...
mick1
Main scooter: Li Avanti 225
Looking good...quite an engineering achievement
What's the radiator off ?
Stampede
Main scooter: SX200
I would cut a bigger hole in there.
Stampede wrote:I would cut a bigger hole in there.
another one in the middle i think
RManson
It's in the cards but before I went making the legshields flimsy with a massive hole, I figured I'd try two smaller ones first. The frame tube blocks most of what would be gained from opening it up and the fan pulls gobs of air through the smaller holes as it is.
The rad is off a Kawasaki street bike.
warts
Main scooter: honda
The old rule of thumb for intake opening is 1/7th the area of the core.
Stampede
Main scooter: SX200
RManson wrote: It's in the cards but before I went making the legshields flimsy with a massive hole, I figured I'd try two smaller ones first. The frame tube blocks most of what would be gained from opening it up and the fan pulls gobs of air through the smaller holes as it is.
Well, i would cut the hole bigger and weld on a bar across the legshield instead of the single hooks on each side - this should stiffen it up again.
I could take a picture of mine if you wish, hopefully there´s isn´t too much snow in front of my garage to get in there. :D
I don´t think the round frame tube will restrict it the air flow very much, it will go around it.
Speed Demon
I made mine with a fecking huge hole there. The good thing about the frame tube it that it cops all the shite thrown up off the front wheel so there's not really any need to add a grille either. With a Husquvarna rad it cools fine without need for a fan, even in the summer.
Anther rule of thumb is to pick a rad not from something with the same CC as your engine, but with the same sort of power output - so anything in the 40hp region should be good for yours.
Get to SULK
    Users browsing this forum: No registered users and 43 guests
