Page 4 of 4
Re: Messing about with a Gilera Runner
Posted: Mon Oct 15, 2012 5:53 pm
by RICSPEED
one thing i have been wondering is what benifits do you expect or in what way is it better going reed in cylinder over the standard crankcase induction ?? is it simply that you can use a bigger reed /manifold and carb set up ??
Posted: Mon Oct 15, 2012 7:42 pm
by Rich_T
The problem with a larger/longer case reed is case studs get in the way, a lot of complicated modification to two parts of the engine (rather than concentrating the majority of changes to the cylinder). This way, a production version would be much easy to install.
Using the existing GT reed and manifold saves a lot of costs, puts the carb in the right orientation and provides several carb options.
I'll have a look at a GTS linkage later this week.
Posted: Mon Oct 15, 2012 8:28 pm
by e type
whats the hole from the water gallery into the bore for ?
Posted: Mon Oct 15, 2012 10:23 pm
by Rich_T
It is an M6 hole that is used to pin the liner in place.
Posted: Sun Oct 21, 2012 12:08 am
by Rich_T
Getting closer to a launch date. Today, top end is built and PV matched up and lift settings adjusted. Just got the linkage to weld up this week and it'll be ready for testing.
Posted: Mon Nov 12, 2012 9:38 am
by e type
Have u fired it up yet ?
Posted: Tue Nov 13, 2012 7:57 pm
by Rich_T
Yes, it has been running for about 2 weeks now. The reedvalve works but it will need a dyno session to help figure out exactly when the PV pulls in (rev range) and get an impartial view on the AFR and engine performance. I have made a couple of collars to lock the variator so that BHP and AFR can be monitored with revs and load. Assembly wise it all worked out very well.
Posted: Sat Jan 26, 2013 6:09 pm
by e type
Pm sent rich
Posted: Thu Jul 11, 2013 10:09 pm
by trev t
WELL WHAT HAS HAPPENED,,, DOES IT WORK OR NOT??????????????????BEEN WATCHING WITH INTEREST...
Posted: Mon Oct 28, 2013 7:20 pm
by grimspeed
I could see that on a T5 ? a PX ?
