Page 4 of 4
Re: Dragging clutch / weird scraping / petrol in gearbox oil
Posted: Fri Jul 06, 2012 10:07 pm
by mushroom
ah ok , so it'll be in my new complete clutch then ?
Could this be why the clutch started dragging ?
Posted: Fri Jul 06, 2012 10:15 pm
by bazman
Yeah i would hope so fella!!
As for causing dragging etc by the sounds of it your old clutch had been through the wars so to speak lol.
It wouldn't have helped but not the sole cause methinks!
Posted: Fri Jul 06, 2012 10:22 pm
by mushroom
bazman wrote:Yeah i would hope so fella!!
:lol:
Cruciform was a bit rounded too :)
Posted: Fri Jul 06, 2012 11:38 pm
by goldeneye
the end of your layshaft looks a bit fooked as well, MK1 gearboxes only shim from one end, and the other end looks nakered. i"d replace that as well, or you"ll have gear jumpin problems from the off. i"ll rake in the shed for one for you. that one looks goosed.
Posted: Fri Jul 13, 2012 1:19 pm
by mushroom
Pulled the old clutch apart and the brass shim was looking a bit sketchy
Posted: Sun Jul 15, 2012 8:55 pm
by mushroom
Had to change every bearing in both case halves in the end as the brass bits were everywhere :cry:
