Gorillaz's
Scootissimo
Loving that.
But preferred the Snetty to the current seat though.
Just my own personal like. But it ain't my scoot....
Wish it was.
CANbus
I have been trying to get back into the mood, here's some more stuff I have been doing of late.
Fitted Side Stand
Replaced the first gear and kickstart shaft, tried out the engine jig at the same time. It seemed to go ok, it can be indexed and locked in 12 different positions.
Also fitted the new BGM silent blocks.
Finally got around to fitting my SIP speedo. Like Minorty from this forum, I have decided to mount the speed sensor to pick up off the rear wheel.
I made a widget that will be pressed and glued into the rear shock bottom mount.
11111111 = 0xFF
CANbus
Fitted the SIP sensor to the scoot today
Fitted and fired up the SIP speedo, view from the cockpit,
Tried out this new digital torque meter, found it to be very accurate, even measures torque for left hand threads, watch out flywheel.
I really must change that seat :oops:
The man cave
I have some new gauges and sensors to fit also, when these are in place then the fun starts.
My control programe is nearlly finished :geek: , it will have some speacial features such as logging, electronic choke
Automatic choke on a pre seleted EGT setting or RPM etc (hopefully a anti seize function)
The SIP catalouge is fantastic even considered buying a Vespa at one point. :?
11111111 = 0xFF
Minority
Main scooter: Li230 S3
Neat solution for mounting the sensor, I like it!
I think the you'll like the SIP speedo, it was certainly a novelty for me having a stable, accurate speedo. :lol:
CANbus
Thanks Minorty.
fitted the gauges over the weekend, I hope to fit the EGT socket to the exhaust downpipe next.
11111111 = 0xFF
CANbus
Gorillaz's on the Dyno this week.
11111111 = 0xFF
Nice work on the speedo sensor, given me some ideas for fitting one on the front
CutdownSpence
Main scooter: 1966 Silver Special
Loving this scoot....proper job ;)
One Of England's Finest Salad Dodger's.
Agree lovely Scoot :D not sure about the seat though ;)
Scootissimo
Awesome scoot. Very envious.
Prefer the Snetty though. Just a personal thing.
And perhaps change the Indian switchgear....?????
