Page 4 of 10
Re: TS1 Sprint/race engine, pics of porting in progress.....
Posted: Mon Jan 02, 2012 2:27 am
by sean brady scooters
can you please put that into english lol
Posted: Mon Jan 02, 2012 2:31 am
by Darrell Taylor
sean brady scooters wrote:ok yes ,but bigger crankcase barell trans would always be better yes ?
the volume of charge held in the transfer duct is less important than the duct shape,
the combined volumes of the duct and case could have positive or negative effects if the volume calculated is too big for your engine design or too small
if you have a 58 stroke 107 rod then bigger transfer ducts would create larger overall crankcase volume and prove useful
but on a 62 stroke 116 rod /large packer the volume may already have been achieved so may not prove useful
Posted: Mon Jan 02, 2012 2:33 am
by Darrell Taylor
sean brady scooters wrote:can you please put that into english lol
what part?
Posted: Mon Jan 02, 2012 2:37 am
by RICSPEED
Shunurl loop maybe
Posted: Mon Jan 02, 2012 2:38 am
ok thanks ...
Posted: Mon Jan 02, 2012 2:41 am
by Darrell Taylor
Muppet wrote: I would think satin finish would be better than polished; if only to prevent pooling?
muppet,
heres your question mark back
i go for a rough textured finish as many university and yamaha white papers ive read on the subject prove its worth on inlet systems
Re: Friendly Late Night Debate About Transfer Ports.........
Posted: Mon Jan 02, 2012 1:18 pm
by Darrell Taylor
no is correct
one of the most basic principles of 2 stroke design often overlooked
designed by adolf schnurle approx 1928
Posted: Mon Jan 02, 2012 1:21 pm
by RICSPEED
over looked ?? i must have missed something ....
Posted: Mon Jan 02, 2012 1:36 pm
by Darrell Taylor
RICSPEED wrote:over looked ?? i must have missed something ....
ta edited
Posted: Mon Jan 02, 2012 1:41 pm
by jonny snatchsniffer
i dont reckon that mahoosive transfers at the bottom of the barrel will make too much difference, say you had a ts1 barrel and dynod it as is and then made the barrel transfers as big as the barrel/cases will allow without weld you will gain very little if anything and the time doing so would be better spent on getting the exhaust port a good shape
does the angle of taper in the transfer duct have an optimum angle ? as if you speed the gasses to much or little will it effect how much charge goes where at a given rpm
