Page 4 of 5
Re: RB250 kit
Posted: Wed Jun 06, 2012 7:13 pm
by jonashford
handy with the grinder!!!
Re: RB250 kit
Posted: Fri Jun 08, 2012 12:58 pm
by Lambretta Sash
Just little update on my RB250.
I'd had issues with carb settings and just could not get it right, so stripped it down to find reed petal had brocken on far side and crack in casing by cylinder stud and transfer area on lower part of casing.
Unfortunately the new engine casing supplied had been machined the full depth to accept spigot and not part of the depth as described in fitting instructions which does leave it weak in that area.
Its been welded up and back together allthough the confidence in the indian casing is not great as i have known these to fail in the past.
Re: RB250 kit
Posted: Fri Jun 08, 2012 4:59 pm
by Lamaddict
Lambretta Sash wrote:Just little update on my RB250.
I've heard about possible casing problems so I'm getting the 125 casing beefed up in those areas when it gets converted by CS Engineering. I think is great to be increasing a casing from 125 - 250 ;)
Re: RB250 kit
Posted: Tue Jun 12, 2012 11:36 am
by Lambretta Sash
I have seen the whole bottom part crack and come away with the cylinder and head attached as one in he past!
If it fails again that will be the route i'll take.
CS Engineering would be the place i would get a casing done too, I get them to do my engineering work as they deal with scooters on a regular basis.
Re: RB250 kit
Posted: Thu Jun 14, 2012 6:29 pm
by Lamaddict
Oopening up from 125 -250! By CS engineering, great job!!
Re: RB250 kit
Posted: Thu Jun 14, 2012 9:08 pm
by joespeed
Lamaddict wrote:Oopening up from 125 -250! By CS engineering, great job!!
was this a spanish 150 case? how much to convert?
Re: RB250 kit
Posted: Thu Jun 14, 2012 9:40 pm
by Lamaddict
No Innocenti S3 one, I just let CS know it was for 250 and he's done it to suit. I'll match up the ports but that's easy.
Re: RB250 kit
Posted: Thu Jun 14, 2012 10:07 pm
by joespeed
Lamaddict wrote:No Innocenti S3 one, I just let CS know it was for 250 and he's done it to suit. I'll match up the ports but that's easy.
costallotti!
Re: RB250 kit
Posted: Thu Jun 14, 2012 10:34 pm
by Lamaddict
costallotti!
Hope not ;) but I'll let you know the cost. From this thread and other people saying just opening up a SIL casing may not be enough.
Re: RB250 kit
Posted: Fri Jun 15, 2012 11:21 pm
by rosscla
jonashford wrote:handy with the grinder!!!
Cheers, you find that works ok, might give it a go with an old cowling.
