Page 4 of 6
Re: Allstyles half head cowling
Posted: Tue Dec 20, 2011 10:38 pm
by wezly
Cowlings just hold the heat in because with the size of the reedblock on ts1 and rb kits theres no cool air from the fan going through the fins of the barrel that side anyway. With this new cowling air flow under the scooter will cool the head when its moving also.
Allstyles have used these for years btw, either these or no cowlings at all.
Posted: Tue Dec 20, 2011 11:43 pm
by jonashford
I might sound like a bit of a twonk here, but has anybody tried adding extra fans to a cowling?? IE small battery operated fan from say a pc? or some other device?
Posted: Wed Dec 21, 2011 8:23 am
by RICSPEED
c e's scoot had a large 12v fan to keep under pannel heat down ,warm fule is a bad thing also
Posted: Wed Dec 21, 2011 8:35 am
by mick1
Could it ne that a full cowling is better for town riding with the "semi" cowling being better for the long hauls ??
Posted: Wed Dec 21, 2011 11:50 am
by mickdale
if warm fuel is a bad thing then surely its better to have the cowling to try to keep the hot air from the cylinder/head away from the inside of the panelwork/frame?
i can understand both arguments but surely it cant work both ways
if one way is better than the other then i'm all for it but i will need to see objective evidence first
Posted: Wed Dec 21, 2011 12:14 pm
by Tom Russell
mickdale wrote:if warm fuel is a bad thing then surely its better to have the cowling to try to keep the hot air from the cylinder/head away from the inside of the panelwork/frame?
Couldn't have put it better myself mickdale :)
Obviously, keeping the cylinder and head as cool as possible is imperative, and if it has been proven that this 'half head cowling' does just that, then awesome, though I'm just surprised we haven't heard more about it already!?
In any event, I can't help thinking that there is a gap in the market for a new design cylinder head cowling (and maybe flywheel cover and fan) that is proven to keep everything cooler, especially for TS1/RB etc. kits where it has previously been stated that these suffer with cooling problems with standard head cowlings.
Posted: Wed Dec 21, 2011 12:40 pm
by RICSPEED
what SHOULD have been done a long long time ago with the ts1 etc is what Ron moss has done with the avanti kit ,there's not a huge scope in improving the efficiency of the current fan design i dont think
Posted: Wed Dec 21, 2011 1:40 pm
by mickdale
just an afterthought - the left hand side rear runner has a "flap" that angles the underside air away from the fan inlet - thus promoting the air to be taken from inside the bodywork.
i assume this was to minimise the risk of road based dirt etc finding its way inside the cooling system. - would it now be better to have angled the rear running board flap the other way to promote fresh air from the outside to be used - maybe with some kind of minimal mesh as a filter without adversly affecting air flow rates?
Posted: Wed Dec 21, 2011 2:09 pm
by RICSPEED
mickdale wrote:the left hand side rear runner has a "flap" that angles the underside air away from the fan inlet - thus promoting the air to be taken from inside the bodywork
for that reason i cut it off :lol:
Posted: Wed Dec 21, 2011 2:29 pm
by Speed Demon
My guess is that feature exists to prevent water splashed up from the front wheel being sucked into the fan and soaking the ignition or cylinder.
