Page 4 of 8
Re: YZ250 conversion
Posted: Sun Nov 20, 2011 3:27 pm
by drew2
oops :oops: ,thought you'd forgot about it :oops:,i have had it
nearly 3 weeks you know
Posted: Sun Nov 20, 2011 4:12 pm
by drew2
just mounted the engine
thats the easy bit done :)
Posted: Sun Nov 20, 2011 6:53 pm
by drew2
bit of bluetack :biggrin: :biggrin:
Posted: Thu Nov 24, 2011 11:23 pm
by drew2
just got the shock and bracket,just seeing how it looks
Posted: Mon Nov 28, 2011 10:57 pm
by drew2
managed to source a swinging arm and mounted it to the shock bracket
just trying to find a suitable spot to mount the shock
Posted: Tue Nov 29, 2011 8:35 am
by twinpooks
looks alot of work , :biggrin: why not mount the shock in original placce and then make your swing arm brackets from your new piece of frame ,so giving you you room fo fuel tank and carb :bouncing: but looking really good 8-)
Posted: Tue Nov 29, 2011 2:36 pm
by tonydevon
not major surgery to the main frame, but some nice result all the same
whats that rear shock from, as your layout is going to need a fairly soft spring? did it come from a bike with rising rate linkage etc?
with the shock in the original location it will need major strengthening to the frame as ll the strength under that seat loop is now gone,
I like the linkage idea, but wouldnt be surprised if you have to move the link point up and the shock down if that springs stiff??
just me personally, but I would look at getting the lever/linkage higher up, so that the shock was laid down up tight to the underside of the loop with the reservoir hanging downwards, then when you make the fuel tank, tunnel the top out to suit the shock, thus hiding it completely
a lot hangs on the rate of that spring
Posted: Tue Nov 29, 2011 6:09 pm
by rocho68
tonydevon wrote:not major surgery to the main frame, but some nice result all the same
The spring rate can be changed to suit once we have the subframe and mounting points fixed :D
Posted: Tue Nov 29, 2011 6:19 pm
by tonydevon
easy sorted then, I wasnt aware if the shock was a rebuildable one or not, or what the range of adjustment on the damping was :)
look forward to seeing this project progress, although mines far further behind, it does make me want to go and work on mine.
Posted: Tue Nov 29, 2011 9:34 pm
by mark
im loving this,its quite inspiring tbh,where did i put that chop frame.lol
