TS1 or RB22 and keep battery?
pete_b
Thanks for your help guys,
I guess the compromise in having a TS1 or RB22 kit on an SX200 is to cut the battery tray off which I was hoping to avoid,
It’s probably not possible to have a standard reed manifold cut repositioned/lengthened then re-welded if no one has done
this mod before.
Looks like I will have to settle for a Mugello instead. :cry:
Cheers.
pete_b wrote:Thanks for your help guys,
this mod before.
Cheers.
There's more space for the inlet on the offside. You can put the battery tray on the nearside instead. Not a huge job.. Easily done inside an hour.
Going for the inferior barrel kit does seem like you're cutting your nose off to spite your face. A very odd move.
