Page 4 of 5
Re: 26 years later
Posted: Tue Feb 19, 2013 9:39 pm
by Boothy_the_makem
Nice one mate. bet you wont leave that out in the garden again :)
What colour is the frame ? Looks pale blue in first photo then grey or white in others ??
As was said in previous post . cant believe no one knocked about that. or nicked it . must of been out of sight.
Re: 26 years later
Posted: Tue Feb 19, 2013 10:35 pm
by Devlam
Its a pale green. I couldn't make up my mind on colour so I got some tester pots out of B&Q mixed em around until I got something I liked, brushed it on a spare horn cast I had, sprayed it over with lacquer and then the guy who painted it got it matched. I like the result and I doubt I'll see the same colour anywhere?
Re: 26 years later
Posted: Tue Feb 19, 2013 10:53 pm
by Boothy_the_makem
Be nice to see it finished. looking good up to now ;)
Re: 26 years later
Posted: Tue Feb 19, 2013 11:13 pm
by stuckintheeighties
Looking really good.
Just a question about the three hole engine mounts- I was lead to believe these are mounted with the bottom hole at 6 o'clock? Sure I read that somewhere?
Re: 26 years later
Posted: Mon May 20, 2013 7:56 pm
by Devlam
stuckintheeighties wrote:Looking really good.
Hmmmm.. I should have come back to this sooner. Occupied with other things.
From what I read you're right. Camlam put these in for me!
How much of a problem is this. On the flywheel side I would say the middle hole is putting slightly higher than straight ahead. On the other side the middle hole is pointing straight forward.
Re: 26 years later
Posted: Sun Aug 10, 2014 3:59 pm
by Devlam
Year 4 -- so it's been a while, but...
Pretty much finished. However, bit worried about the amount of smoke I'm getting out the exhaust...... :|
Re: 26 years later
Posted: Sun Aug 10, 2014 5:28 pm
by bikegunn
Looks great well worth the wait
Re: 26 years later
Posted: Wed Aug 13, 2014 9:43 pm
by wrecklessrobbie
Did I notice your fork tube bump stop had broken off when fitting the forks.
I have recently stripped my s2. The tube stop fell out. I had to weld it back on.
I don't think you can pass an MOT without a bump stop. Have you rewelded it?
Robbie
Re: 26 years later
Posted: Sun Aug 17, 2014 5:04 pm
by Devlam
Cheers Robbie -- It's fixed but I didn't want to weld because it had all been painted. I fixed it in place with JB weld, then drilled and tapped it. Put a couple of bolts in then remove as much metal as I could - then touched up. It looked Ok, but is now hidden anyway. So all good.
Re: 26 years later
Posted: Mon Aug 18, 2014 7:00 pm
by wrecklessrobbie
Ah that's good.
The scooter looks fantastic.
Some hard work and effort gone into it.
I have a big pile of stripped down s2 eibar. :)
Am now working on doing a kind of restoration. If it turns out half as good as yours I will be happy :)
