Re: Toolbox Flywheel Holder
Posted: Fri Sep 03, 2010 4:23 pm
Oh, and if any Fecker goes into production on this innovation
I want some ackers for the design
Guyssoulsurfer wrote:
dapper wrote:Well, here's the Mark 11 version. As stated, you can drill several holes to make it lighter, if you want. I used two 12mm. X 30mm. bolts which were just the right length for my stator. I also checked the torque rating of the clutch centre nut in Sticky's bible, against the torque setting for the flywheel nut, and they are almost the same. So you could use thinner plate, like 2mm. such as the clutch holding tools are made of, but you might have to put a nut against the other side of the plate to give some strength at that point, to stop the plate flexing when tightening/loosening. Make sure the centre hole is big enough to take your 17mm. socket with a bit spare. I've stated 25mm. which should be enough. Now get to your workshops, ya Feckers![]()
soulsurfer wrote:Thinking about it and looking at this design, it doesn't need to look like a table tennis bat, does it? Why couldn't it be made from straight flat bar, it'd be lighter too?
Dapper put me down for one felladapper wrote:Being bat shaped it sits nicely against the tops of the fins to help brace it whilst you undo/do up the centre nut. Now, I have spent some time finishing this prototype off, and will post a photo later. Its had loads of holes drilled to lighten it, but remember, I made it out of some old 5mm. plate I had lying around. It can be made from 3mm. or possibly 2mm. plate which would be strong enough and obviously lighter. The othe reason for it having a large flat round area, is so that if you had a three window flywheel, you could drill three corresponding holes to line up (like an isosceles triangle), as well as the two holes for a two window flywheel. Agreed, any unecessary metal could be removed providing it didn't affect the integrity of the tool for its purpose.
Be back in a while with a photo. Anyone have a 3 hole flywheel from which they could measure the distances for the holes?
Oh, I did make enquiries at a small factory next to my mate's spray shop who could knock out 50 of these in half an hour on their expensive fancy machine, but haven't got any costs yet. If there was sufficient interest, I could get some actual costs together. Don't think they would turn out that dear.
