Page 4 of 9
Re: SPARK MAGNIFIER!!!
Posted: Wed Jun 30, 2010 9:48 pm
by Dazza
All epoxied up and ready to go:
Started ok but won't try a run till tomorrow night....
Posted: Sun Jul 04, 2010 5:16 pm
by Dazza
Well, I made cleethorpes and back with it on, it did seem slightly crisper, I think I may have used slightly less fuel than normal as well, worth fitting it? Jury is still out on that one I Think
Posted: Mon Jul 05, 2010 6:46 pm
by minotaur
........well ordered one last week, arrived today, took 2 mins to fit and my gp with casa 185 does feel crispier and a little more lively up to 1/4 throttle and a tad smoother after that.
it makes the scoot a little better to ride
Posted: Mon Jul 05, 2010 11:23 pm
by soullad
really need a dyno run before and after, to compare, esp the A/F ratio .... Sean, Dan?
Posted: Mon Jul 05, 2010 11:28 pm
by drunkmunkey6969
soullad wrote:really need a dyno run before and after, to compare, esp the A/F ratio .... Sean, Dan?
Someone send me one and it will be done.
Posted: Mon Jul 05, 2010 11:34 pm
by sean brady scooters
yes looking forward to testing those out...
Posted: Tue Jul 06, 2010 7:09 am
by Dazza
drunkmunkey6969 wrote:soullad wrote:really need a dyno run before and after, to compare, esp the A/F ratio .... Sean, Dan?
Consider it done,
Posted: Thu Jul 08, 2010 2:37 pm
by KTy
Another piece of advice; when you mount a Spark Magnifier (SM
), it is a good idea to change the spark plug, if it is in its end-of-life the SM could finish it faster
As for dyno, the guys on the GSF already did some, but it is worth mentioning that the SM usually brings a better "feeling", engine is more "round"; so don't expect more than ~5% power increase (some saw ~10% on some RPM range), but for sure a smoother curve.
Furthermore, you should dyno from very low-RPM if possible because it is more "visible" between idle and mid-rpm...
Cheers,
Posted: Sat Jul 10, 2010 6:41 am
by Special X
Emporers new clothes?
Only a back to back dyno run will tell. My money is on no discernable difference.
Posted: Sat Jul 10, 2010 7:47 am
by Muttley McLadd
Special X wrote:Emporers new clothes?
What if there's no visible difference, but it
feels better?
