Page 29 of 32
Re: SIP Lambretta Digital Speedo
Posted: Fri Sep 09, 2016 8:29 am
by Bilko
Tried it off both yellows from the Wassel and still nowt.
Posted: Fri Sep 09, 2016 8:43 am
by Bilko
Going back to the digital speedo drawing board. Brain frazzled! In the meantime old standard non working speedo.
Posted: Tue Oct 04, 2016 11:18 am
by Bilko
Finally got the speedo fitted and working but a couple of questions.
1. The speedo constantly flashes FUEL even though I've not long filled up?
2. Trying to adjust the clock on option 5 but where the clock is it just has 3F 7F and when I try to adjust it
Posted: Tue Oct 04, 2016 6:27 pm
by Bilko
Oh and I forget to mention the speedo doesn't work either.
I've made some costly mistakes in my time, but this is up there with the others.
Most elaborate rev counter ever.
Posted: Wed Oct 05, 2016 10:23 am
by Minority
Sorry to hear of your problems, I rate my Mk 1 SIP speedo as one of my best purchases for my lammy!
Have you checked that the wire for the fuel sensor isn't shorting to earth and what fuel tap are you using it with?
Speedo using cable or sensor?
Posted: Wed Oct 05, 2016 10:43 am
by Bilko
Thanks for the reply. Speedo sensor is the Ext sensor.
Petrol tap came with the speedo.
Posted: Wed Oct 05, 2016 4:02 pm
by Minority
Does the blue light on the sensor go on/off as it passes over whatever it is sensing ( magnet, bolt head etc)?
Posted: Wed Oct 05, 2016 7:18 pm
by Bilko
Yes.
Posted: Thu Oct 06, 2016 2:00 pm
by Minority
Sounds like your doing the right thing, might be time for an email to SIP.
Keep at it, it's quite a novelty to have a stable accurate speedo on a lammy
Posted: Thu Oct 06, 2016 4:07 pm
by Bilko
Now the rev counter has died leaving me with working but a CHT! I bought it a couple of years ago and only getting round to fitting now so it's for the bin!
Thanks for the help though
