Page 27 of 29
Re: Lince 200 o-tuning à la mode fastfrog
Posted: Sat Apr 11, 2015 5:46 pm
by fastfrog
Ok thanks, I'll try. It has already no play left....
Posted: Sat Apr 11, 2015 6:18 pm
by eden
did you check the plates had space between them with the clutch compressor tightened down when you installed it?
what clutch lever have you used?
Posted: Sun Apr 12, 2015 10:05 am
by fastfrog
Nop. I'm good for a little splitting and checking the whole thing. You can imagine how happy I am....
Posted: Sun Apr 12, 2015 8:42 pm
by slidingdog
sounding daft! but have you tried cutting the handle bar lever to get more "movement"
Posted: Mon Apr 13, 2015 9:26 am
by fastfrog
I bought the yamaha MB conversion lever. Looks fine and easy to pull even with MB springs.
Posted: Wed Apr 15, 2015 8:38 pm
by fastfrog
Ok, got the whole thing apart and found quickly what was going wrong: I forgot to fit the clutch nipple on top of the pressure flange. Sounds french doesn't it? I made less than one km and the nipple onto of the flange was almost destroyed. Just time for ordering the missing parts and à moi la route!
Posted: Thu May 07, 2015 10:52 pm
by fastfrog
Lince back home and first road trials. Very pleasant engine indeed. Obviously a bit too lean on main but rideable anyway. lots of guts and no inertia like an old fashioned 2 stroke KTM. Breaking still in its running in process. Shocks are the revelation. Standard 30 years old serveta front and rear absorbers are just one step beyond some new curry/thailand crappy ones available in term of confort and road handling. Just amazing....
Posted: Thu May 07, 2015 11:40 pm
by Dimitrios_231
Ola-la :D ,
it looks amazing,jet it safely and enjoy it,
I've never managed to fit my S-BOX,
check this link if you are interested there also some others in the same situation,Mr. RC166 is me :)
http://www.germanscooterforum.de/topic/ ... ht/page-17
I don't want to spoil your topic with the exhaust problem,
the Lince looks great ;)
Posted: Fri May 08, 2015 7:53 am
by fastfrog
Exactly the same prob. S-box stub is way out of the cylinder flange when box fitted (hardly) to the chain casing. One idea was to cut a slice of the down pipe and weld it back. But that sucks a lot to do Marco's job. I got the exhaust for more than a year and Marco never answered my questions either; I'll never buy him a pipe again. This is not the way I want to be treated. S-box is full of promises but needs a serious adaptive work to fit properly. Anyway this fitting issue is a further project when I'll get pissed off by the gori's noise.
I'm beginning my carb fine jetting today.
Posted: Fri May 08, 2015 8:23 pm
by fastfrog
initial carb setup: PJ: 54 MJ: 110, X2/266AS now PJ:54 MJ: 121 still a bit too lean. Next try with PJ:54 MJ 125 Sounds close to the average set up.
