GT big block experiance : New GT crank info added
eden
Just took my franrace off to see where it was blowing from and found this :shock: omfg
no wonder she nipped up, even more amazing that it hadn't lost more power than it had.
1469leach
Main scooter: jet200/rapido 225
I bet you're fed up Fred Eden with the nip up,like you said tho you seemed to still have a fair bit of power being delivered from the motor despite the exhaust problem! What temps were you reading when it heat siezed on the rtse 1000?
paul d
Main scooter: T5 172 Tv 240
Every time I watch those vids I think of old man innocenti above the clouds proudly cheering his scoots on! Great thread.
eden
nar nip ups are no problem as long as the rings dont smear over, was only reading 185 which is high ish but not as high as ive seen before, in the Swis alps at 10:30 pm one night in June I had it as high as 195 on the motorway with out it nipping up, problem here is that it was running slightly weaker due to the hole, I know it was weaker because it was ticking over 400 rpm higher than normal, running that much weaker meant the piston built up too much heat too fast before it could transfer that heat to the head and onto the gauge. It ran up to 75mph with no problem at times during the rest of the trip home. it nipped up about 100 miles from home so its done enough miles to run out any smeared aluminium on the rings.
Im fed up of breaking exhausts though, 2nd one in less than a week and both in different places!
2 more rallys to go this season before the engine gets a strip down. Northern Ireland and Brid.
Yanker
eden wrote:Did Woolacombe last weekend, another 420 miles covered.
Had a broken exhaust on the way back making the motor run weak, but ran into Martin on his targa so it all got a bit silly :lol:
Haha Menkul from Penkull, noiyse woun innit.? If youw neiydz a deyscunt english mayde exaws fer ta skewtaz, yaz gotta sey Jon: http://jahspeedscooters.com/contact/2304628 serious lyke! :-) Dems da dogs wot ey duz!
eden
might try one of the LUDWIG & SCHERER pipes.
Yanker
The 'Tourist' is the one designed for the TS1, ALL are for 190+ deg exhaust though......Mathias's exhausts are very well made.
mickjr
ian at taffspeed has been testing it on the GT kit for a while and sorting out some port issue(exhaust?)I was looking into getting one and mathias said ian had one and mb has one for testing off phillip at sck.mark recons much better than the franz race,but it needs strengthening around silencer area,ian said that to
eden
Some more footage from Woolacomb, not motorway miles for a change though, this is a small road in Devon which seemed to be up hill for miles and miles.
great road to ride, just wish it hadn't been the first time I had rode it. be fun if you knew it well!
Jazzy
Get that bloody shocker fixed, must be Like riding. Jet ski.
