Page 3 of 3
Re: GP Bulb holder
Posted: Tue Sep 11, 2012 2:49 pm
by Boothy_the_makem
ordered from scooter restorations today,
i mentioned recommended from scooterotica ;)
Re: GP Bulb holder
Posted: Thu Sep 13, 2012 10:16 pm
by Boothy_the_makem
Arrived today, lights working again ;)
Re: GP Bulb holder
Posted: Fri Sep 14, 2012 6:58 am
by mnpes
Hi Andy ~ Whichever Headlight connection block you fit this will help
First cut all the Nasty Bullet Connectors off going to the Headlight Block
Solder (Tin) all the Conductor Ends ~ Then Crimp on (Amp Type) Bullet Connectors
Use a Decent Crimper
As for the Headlight- Connector piece
Solder all underside connections ~ They are Generally Loose
Decide on a Good Earth Point ~ Preferably not the Rod Control Clamp Bolt
A Brass Nut and Bolt drilled somewhere is ideal
A Cheap Little Conversion
Bin the old type bulb and replace it with a H4 type holder ~ About a £1
These come with 3 wires already attached ~ Generally Red - Blue and White
Red and Blue correspond with the Main and Dip
The other wire Crimp and Solder to a Good Ring Terminal ~ Amp Typ
The Ring Terminal then fitted on the Brass Nut-Bolt and Washer
Check the Soldered Joints on the Dip-Horn Switch ~ Indian Soldering is like their Welding
That should be the end of your Headset Troubles ;)
