ts1 fuel %
bazman
Seems 3% is the general consensus , I've always ran at 4% .....but seems a hell of a lot oil and does have an oily, black tailcan....but do i dare go down or stay same decisions decisions :lol:
SCREWDRIVER
bazman wrote:Seems 3% is the general consensus , I've always ran at 4% .....but seems a hell of a lot oil and does have an oily, black tailcan....but do i dare go down or stay same decisions decisions :lol:
and then wen it's too late remember what Andy's said to ya ...... for year's 4%
Rosi-C9
2% Castrol TTS (or 2RS) with 98 octane fuel. Works well for the last 15 years (TS1 200/225 and 172 Malossi). Never had problems with the big end bearing.
Edit: 2 instead of 4% :?
bazman
Very true fella :geek: :lol:
martinr
slade wrote:what sort of rideing are you lads doing on 2% oil? motorway,A road? RPM? miles per year?
thrash the tits off it as much as i can lots of rallys kelso last year 600 miles in two days no probs :D
DJB
4% :shock: Do you have shares in opec. 2% is plenty and i always cane mine euros and uk
GP Kevo
Well, if you're going to do a long motorway ride then adding extra oil is a good idea but around town 4% is too much for a good, fully synthetic 2T like Motul 710, 800, Castrol TTS or Rock fully synth (at least for these oils in my experience). :-)
Skar
GP Kevo wrote:Well, if you're going to do a long motorway ride then adding extra oil is a good idea
I often read/hear this but I'm pretty sure it's not true, by adding extra oil you are leaning your fuel/air mixture and therefore are more likely to have problems.
bazman
Yes possibly but your carb would already be set up to counter this? I think it's more to do about the big end getting enough lubrication at sustained reasonably high rpm ( for a scooter) :)
Certainly wouldn't add any more than 4% though :shock:
J1MS
I usually run mine at 4%, having in the past tried 3% and for a short period 2% but the big end let go at 2% taking out the barrel head and piston. At 3% the small end eye was worn and so was the big end. But the engine had done a couple of years running on 3%.
The extra cost of a bottle of two stroke oil every thousand miles gives me a little piece of mind, but I will still run mine at 3%, but not all the time, more when doing short trips or local ride outs.
    Users browsing this forum: Google Adsense [Bot] and 5 guests
