Re: inboard disc caliper
Posted: Tue Feb 23, 2010 9:42 pm
ok, fitted today, bled brakes in around half an hour, there was air trapped in the hidden master, so had to lean scoot by 45 deg.
the caliper is well machined and the piston very tight in the bore, fitted with a vented disc and newfren sintered pads and a new mbd stainless circlip
initial test run i was very impressed, controlled sharp front disc brake.
they look like a scootrs caliper but with larger and solid stainless piston which has jap 30mm double piston seals, easily and cheaply bought.
i tried it against a new scootrs caliper but the seals were leaking so not a good comparison , the scootrs circlip is not very thick also and allows more play with the caliper.
i have a scootrs caliper in my gp with non sintered pads and non vented disc , i will do a swop the weekend and see if the new caliper improves things.
for those who want to keep an inboard disc i recommend this
and i don't think it's andy horn, maybe it's andy brake
