Page 3 of 3
Re: Flywheel center boss swap question???
Posted: Thu Jan 21, 2010 4:37 pm
by soulsurfer
RICSPEED wrote:i guess you'd have to make up a plate/adaptor to fit lammy or vespa rims to a balancer
PM/Frank hub centre plate?
Posted: Thu Jan 21, 2010 8:58 pm
by shocky
IS YOUR BALANCED
its easyier with this type of hub if you were gonna do it with standard stuff you would need the rear hub and the nearside half from the front to get it right , the back is esier becouse of the tapered cone but the mounting spindle on the balacing machines is too fat to fit through so it cant be done really you could make a disc and balance that then mount the tyre/rim and balance that and that would be better than nothing but becouse the plate would be offset i dont know if it would work .............. who knows its a minefield
