Re: schwalbe power track tyres
Posted: Thu Dec 24, 2009 10:21 am
No such luck there its Indian..should be able to file with a toothbrush..
do yo want some big bags of italian filings we have loads here and they are very cheap, couple of pints of johns should do it :biggrin: :biggrin:Lam46 wrote:No such luck there its Indian..should be able to file with a toothbrush..
soulsurfer wrote:If you sit on it, surely the tyre will bulge at the bottom, not at the side where it'd rub the casingLam46 wrote:I know with mine which I run wide rim 100/90 on the rear it has clearance from the engine case even sat on it theres a gap...
But not if you're stationarymouse wrote:For those of you who think the tyre will bulge only at the
bottom are wrong. Imagine at speed under compression the tyre will
deform and send that bulge around the whole tyre.......
we dont sell stationary, only top quality scooter parts :biggrin:soulsurfer wrote:soulsurfer wrote:If you sit on it, surely the tyre will bulge at the bottom, not at the side where it'd rub the casingLam46 wrote:I know with mine which I run wide rim 100/90 on the rear it has clearance from the engine case even sat on it theres a gap...But not if you're stationarymouse wrote:For those of you who think the tyre will bulge only at the
You need paul green for that..mouse wrote:we dont sell stationary, only top quality scooter parts
That's quite a chunk taken out
Thanks for this i had a look this morning there is a faint polished line on the engine case and a small mark on the tyre where the clutch arm is, so after xmas i will have a go at spaceing it if that dont work 3.50/10 it ismouse wrote:we don't advise using 100/90 tyres on wide rims, you can use a 3.50 on a wide rim or a 100/90 on a standard rim but you should be very careful using 100/90 on wide rims, remember the tyre expands when it gets warm!
