Page 3 of 3
Re: VESPA DYNO GRAPH POSTING AREA
Posted: Sun Feb 12, 2012 11:36 am
by Train Driver
[/quote]
This is what I'm looking for, but about 4k revs earlier
anyone ???
Posted: Mon Feb 13, 2012 10:39 pm
by Diablo
Heres Mongos T5 which I must admit turned out better than I expected it to.
Engine is:
Polini barrel bored to 64mm and some exhaust port work. Suzuki TS185 piston
T5 crank gasflowed using a DRT eccentric pin to give 54mm stroke built by Pro Porting
Taffy Pipe
M-Tech retarder
Std carb with 135mj flowed inlet
Pulls 22/68 very easily
19hp 16ft/Ib torque
Posted: Tue Feb 14, 2012 1:59 am
by Train Driver
Diablo wrote:Heres Mongos T5 which I must admit turned out better than I expected it to.
Engine is:
Taffy Pipe
M-Tech retarder
19hp 16ft/Ib torque
Al
that dip from 4000 to 5500 what causes that
Posted: Tue Mar 06, 2012 12:10 am
by MattsDad
Train Driver, why are you looking for this, its a scoot that has seized?
anyone ???[/quote]
Posted: Wed Mar 07, 2012 10:59 am
by gimp1971
Heres mine 172 t5 with malossi reed valve and 128 carb with a scorpian got a taffy on it now and going to put a 21 tooth cog on clutch plus chris said he will open exhaust port on it a bit so will post another up after work done to see if any difference
Posted: Thu Apr 05, 2012 12:14 am
by cezeta
anyone ???[/quote]
then ride your lambretta as thats what you have. vespas are for shopping.....my polini is like riding a ride on mower.
Posted: Fri Jul 26, 2013 9:07 pm
by H,POOL GADGE
http://farm8.staticflickr.com/7368/9373 ... e947_b.jpg
dyno reading - vespa px200e - polini alloy 210-pinasco reprofiled head 10:1-pinasco 60mm crank-24/24si carb 48/100 idle-140 air corrector-be3-125 main-standard 4th gear- carb inlet timing opened-crank inlet timing opened-exhaust port widened a touch -JL r/hander -
pulls like a galloping horse, uphill and head on wind, with a dollup of high rev fun factor, over the moon with setup, 19 BHP + 17 TORQUE!!!
tune, work and dyno cutiously done by the legends DAN & SEAN @ Scootererotica!!!
Posted: Fri Jul 26, 2013 10:57 pm
by drunkmunkey6969
Lol....cheers Gadge.
Note...you have highlighted the curve incorrectly, you've started with BHP in black and then at the point where they crossover you've followed the torque curve. I'll see if I can re-post a correct image
Posted: Thu Oct 30, 2014 5:45 am
by culturesponge
here's my Worb5 Malossi 210 motor dyno from Jan 2007
alex
