Page 3 of 4
Re: Scootrs antidive
Posted: Fri Oct 02, 2009 6:25 am
by scootRS.com
>>I'm not sure your definition of a Rose joint is the same as mine then.
Unlikely, given I'd never heard of a "rose joint" before recently
Sorry, half the time I don't know the technical terms in British English, and often not in any English, I know most of them in Vietnamese only which is what we speak at the shop.
Anyway, my point is that they aren't simply plain bolts otherwise you'd lock everything in place. They allow rotation. Rotatabolts? Boltators?
Cheers.
Posted: Fri Oct 02, 2009 6:58 am
by joespeed
scootRS.com wrote:>>I'm not sure your definition of a Rose joint is the same as mine then.
Cheers.
could this be a 'shoulder bolt' or stepped bolt' ,the 'rose joint' has been around for many years used in aeroplanes,cars,tractors and industry,an easy way to describe this is a ball with a hole in it possible an arm or bracket attached around the ball to allow movement/pivot action,a typical example is a car suspension,
a picture may help identify its correct term.
regards
joe
Posted: Fri Oct 02, 2009 10:32 am
by scootRS.com
I'm going with "boltators".
I think Frank uses boltators as well, looking at that photo above.
Posted: Fri Oct 02, 2009 12:19 pm
by mark
this is a rose joint , any chance of a pic of yours randall please?
have you ever considered a twin disc wheel randall?
Posted: Fri Oct 02, 2009 1:17 pm
by soulsurfer
scootRS.com wrote:I'm going with "boltators".
Dunno what a boltator is, but I do know what a rose joint is. Frank doesn't use rose joints, he uses a bronze bush at the axle and standard bolts with bronze bushes at both ends of the tie bar. The bolts are nipped up using a Binx nut to allow rotation.
http://www.conceptfasteners.com.au/Prod ... le2-BX.pdf
Posted: Fri Oct 02, 2009 7:09 pm
by sideout
joespeed wrote:could this be a 'shoulder bolt' or stepped bolt' ,the 'rose joint' has been around for many years used in aeroplanes,cars,tractors and industry,an easy way to describe this is a ball with a hole in it possible an arm or bracket attached around the ball to allow movement/pivot action,a typical example is a car suspension,
regards
joe
Yes Joe, it is indeed a shouldered bolt. That's why I said it was in my post:
sideout wrote:........... The kit you sent me contained two fitted, shouldered bolts, not Rose joints actually. .......
Posted: Fri Oct 02, 2009 7:27 pm
by joespeed
sideout wrote:joespeed wrote:could this be a 'shoulder bolt' or stepped bolt' ,the 'rose joint' has been around for many years used in aeroplanes,cars,tractors and industry,an easy way to describe this is a ball with a hole in it possible an arm or bracket attached around the ball to allow movement/pivot action,a typical example is a car suspension,        a picture may help identify its correct term.                 regards                  joe
 :lol:
i have not looked very close at this,does the caliper mounting plate pivot on the main axle spindle or is it as usual that is either with the plate onto the fork link spigot or bolted on to the fork link.if it is pivoted on the axle then there is no need to run disc links ever again,        a picture of a kit not attached to the scooter would verify this,        question is,does it work? i didn't see any racers with them on at cadwell!
regards
joe
Posted: Fri Oct 02, 2009 7:57 pm
by soulsurfer
It's not attached to the fork links at all so it doesn't matter which links you have.
Posted: Sat Oct 03, 2009 5:54 am
by scootRS.com
mark wrote:have you ever considered a twin disc wheel ?
I don't really see the point of a twin disc kit. Only more complicated and more expensive. One disc is more than enough stopping power.
Posted: Sat Oct 03, 2009 8:45 am
by CPH Lambretta
Hi Randall,
I have a Scootrs disk I want to upgrade to anti dive but I bought the disk "new & unused" from a member on here that had a change of plan. How or when can I buy the upgrade kit? As I uderstand it the upgrade is only offered to people who got an email from you?
