Re: imola ppl need advice on additions???
Posted: Wed Oct 07, 2009 8:30 pm
Quite interested in the differences too, can the older kit be brought up to the same spec?
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
I've no idea on that one but a call to Camlam should answer that.Bofs wrote:Quite interested in the differences too, can the older kit be brought up to the same spec?
I didn't have one to compare it too Mark so can't say. The big noticable difference was the head which had a reworked bowl and also a 5 point fixing system using the four studs and a head bolt.J1MS wrote:Diablo wrote:Theres a big difference in power between the old imola kit and the new one with revised cylinder head and I think inlet?
I built one earlier this year and it made 22.5hp on our dyno with a JL3 and a 30mm mikiuni.
Camlam brought theirs up for the smallblock shootout with a JL4 on and it made the same so no fluke.
To put it in perspective a std TS1 makes 20hp on our dyno.
What was most impressive though was the torque. I haven't got the figures to hand but it blows the old imola away everywhere. So much so that 5.2 was too low geared on this bike and needed either 5.0 or even 4.8.
quote]
Al, What are the differences between the old and new Imola's is it an obvious visual difference or revised port time areas..??
that wasnt the one on ebay a few weeks back was it?CPH Lambretta wrote:I just bought an exdemo Imola kit from Camblamb thats been reworked by Charlie Edmunds , they said its been tweeked ,has a one off center squish head and Boysen reeds.
I'm planning to run it with a 30mm powerjet carb and a JL4, I'm really looking forward to it, should be fun.
The new Imola has a double boost port in the inlet and a double apex reed valve. Also the head is center squish with a 7 point fixing.J1MS wrote:Diablo wrote:Theres a big difference in power between the old imola kit and the new one with revised cylinder head and I think inlet?
quote]
