Page 3 of 3
Re: Stuttering & four stroking
Posted: Sat Jun 27, 2020 6:29 pm
by Smudge
You say at low revs so maybe your idle is too rich for the conditions, try dropping down a size and see what it is like. 10 minutes effort and you may be sorted.
Posted: Sat Jun 27, 2020 7:47 pm
by Lambretta67
Thanks I will give that a go.
Posted: Sat Jun 27, 2020 8:15 pm
by hat
Could try backing off on the mix screw a touch as well, maybe quarter to half a turn leaner
Posted: Sat Jun 27, 2020 9:03 pm
by Lambretta67
I will try anything suggested
Posted: Mon Jun 29, 2020 9:20 am
by EddieStone
Have you checked your choke cable is adjusted properly? I adjust mine so there's a bit of slack in the cable when it's off. I'd check that as well, make sure the plunger is clean and closes properly.
Posted: Mon Jun 29, 2020 11:39 am
by Lambretta67
Would it still tick over if it wasn't adjusted properly. Because it ticks over fine. Was going to check scoot last Sunday but I pored down
Posted: Thu Jul 02, 2020 10:42 pm
by EddieStone
Not enough slack, it seems. Bloody choke cable snapped at the nipple today!
Posted: Fri Jul 03, 2020 5:27 am
by Lambretta67
That's a bit of bad luck. Hoping for a dry weekend so I can sort my scoot out
Posted: Sun Jul 05, 2020 3:10 pm
by Lambretta67
Took the scoot out today still ran badly but not as bad as the really hot day we had . Adjusted the mixture screw a quarter of a turn in & it runs fine now. Thanks everybody for all the advice .
Posted: Mon Jul 06, 2020 8:25 am
by hat
good news, thanks for letting us know. amazing how tiny alterations can make all the difference some times
