Page 3 of 3
Re: Anti dive for spauq
Posted: Fri Feb 07, 2020 2:46 pm
by Simon lambretta
I think I’ve probably set up wrong, but thanks for your advice and knowledge.Ive ungraded my fork springs with mb.And adjusted the dampers a little harder.Suits my style of riding
Posted: Fri Feb 07, 2020 6:35 pm
by wrecklessrobbie
I think disc brakes / anti dive are a bit like marmite.
Some people love them some dont.
Its good that you have a workable solution. Hopefully you will have trouble free riding.
As for mine bearing in mind what Minority had said, when i got in from work, straight into the shed and checked mine.
The disc has a new back plate, that locates on the lug on the trailing link. Its well and truly located.
I thought it did but had to recheck just to reassure myself.
Posted: Wed Feb 26, 2020 2:09 am
by rosscla
The caliper carrier for disk / drum is different with no AD.
With the AD it should be the same. The AD arm should be roughly parallel with the line between the axle and the link pivot bolt. Too low and you get a lot of dive; too high and you don't get enough potetnitally causing skip under hard braking.
The AD should have no impact on normal suspension operation when not braking.
Under braking it should transfer the rotational force to the fork leg rather than to the links causing dive.
