Page 3 of 4
Re: Scooter not picking up properly ........... HELP!
Posted: Mon Oct 01, 2018 1:40 pm
by alanscottj
johnny650 wrote: ↑Mon Oct 01, 2018 1:23 pm I'm inclined to agree with Daggs that it is a carb issue .
Clearly it is only effecting the throttle pick up off of idle by your description .
The idle is presumably stable so rather than the Pilot jet or air jet it could be the slide...... the slide is responsible for pick up off idle to approx 1/8th of throttle range.
Try this simple experiment. next time you go to pull away apply a little choke and see if that improves initial pick up. if it does pick up better then it would suggest you need to change your slide to a richer one .
from MB Scooter site 'Dellorto slides 26 - 30mm PHBH 30 35 40 45 50 55 Alloy
Have tried a 40, 45 and a 50 slide and have tried with choke :|
Posted: Tue Oct 02, 2018 9:27 am
by alanscottj
Just checked spark this morning and it is intermittent - that is with a new CDI
Posted: Tue Oct 02, 2018 3:04 pm
by johnny650
crikey don't ya just hate intermittent sparking issues .
Its probably worth going over all your ignition system connections and earthing points and give them a clean . Its starting to get damp in the mornings and that can sometimes uncover lots of poor electrical connections
Posted: Wed Oct 03, 2018 11:53 am
by alanscottj
All sorted now - combination of a couple of things I think. Replaced stator so now getting a good consistent spark, timing reset at 18 degrees, also changed slide to a 35. Scooter is starting well again, first or second kick and pulls away nicely, not perfect, but much much better than it was. Now I have an oil leak - haha - always something!!!!
Posted: Wed Oct 03, 2018 3:29 pm
by HxPaul
If I were you I'd go back to using a 40 slide in the carb.
Posted: Wed Oct 03, 2018 9:01 pm
by alanscottj
HxPaul wrote: ↑Wed Oct 03, 2018 3:29 pm Sent from my SM-A320FL using Tapatalk
How come?
Posted: Wed Oct 03, 2018 10:20 pm
by storkfoot
alanscottj wrote: ↑Wed Oct 03, 2018 9:01 pm
How come?
Where is “oil” leak from?
You may be richening up your air mix, by going to that size of slide, to mask an air leak.
Posted: Thu Oct 04, 2018 10:17 am
by HxPaul
How come?
Because you changed 2 things,now you dont know if the new stator plate cured the problem or changing the slide cured it.
Posted: Fri Oct 05, 2018 6:28 pm
by alanscottj
HxPaul wrote: ↑Thu Oct 04, 2018 10:17 am
How come?
Ah, good point! I'll pop the 40 in tomorrow and see how it goes :D
Posted: Fri Oct 05, 2018 6:29 pm
by alanscottj
storkfoot wrote: ↑Wed Oct 03, 2018 10:20 pm
How come?
Oil is definitley coming from side casing - however, I intend to do a leak test over the weekend ;)
