Page 3 of 3
Re: No spark
Posted: Thu May 24, 2018 4:55 pm
by coaster
mattyboyc wrote: ↑Thu May 24, 2018 4:19 pm Thanks, for your reply.
One of the guys I work with said straight away it would be the stator pick up box, so is this looking like the culprit?
I agree that the pickup is a little low but it isn't far off, I would be inclined to try a different CDI first. Indian can be bought off ebay for less than £15 and even if not the cause, are handy as get you home spares or for testing opportunities like this. I must have 4 or 5 of the things, where are you based?
Colin
Re: No spark
Posted: Thu May 24, 2018 5:11 pm
by mattyboyc
Hi,
I am in Aldershot Hampshire and usually use Allstyles for my scooter parts, I’m not sure on posting photos on here yet but I could email you a link of a cdi they sell to see if that would be ok.
Thanks again.
Re: No spark
Posted: Thu May 24, 2018 5:19 pm
by mattyboyc
Is there any way of testing the cdi before swapping, and if I do swap is a Ducati one any good?
Re: No spark
Posted: Thu May 24, 2018 9:22 pm
by coaster
Unfortunately there are no tests that can be done on the CDI which is why I'm suggesting buying a very cheap one just for substitution when you have ignition failure. There's one on ebay at the moment fro £8.45 plus postage and its in the UK https://www.ebay.co.uk/itm/Vespa-or-Lam ... xyu1FRjq03 or you could bite the bullet and buy a Ducati one and if that doesn't cure it you can keep your old one as backup.
Re: No spark
Posted: Thu May 24, 2018 10:04 pm
by mattyboyc
I see your point,I’ll order one and have mine as a spare if that does not cure the issue.
Thanks again for all your help.
Re: No spark
Posted: Tue May 29, 2018 3:00 pm
by mattyboyc
Just a quick update, I changed the stator pick up box and got the spark back, put everything back together and she fired straight up, now on to setting up the gears again.
