Page 3 of 3
Re: New Layshafts?
Posted: Sun Mar 18, 2018 11:43 pm
by rosscla
corrado wrote: ↑Sun Mar 18, 2018 1:08 am
garry inglis wrote: ↑Tue Mar 13, 2018 9:34 am The Casa ones are very good I have one in my ts but I would look at the new 18 spline layshaft kit £280 You get the hub, bearing, seal, layshaft, nut and washer plus they will be spot on for a 5 speed box
It's actually cheaper than buying a "safe" hub and an "MB" layshaft.
Doesn't include the wheel?
And BTW is the wheel interchangeable on the front?
Re: New Layshafts?
Posted: Mon Mar 19, 2018 5:59 am
by garry inglis
Yes you can use it as normal on 4 bolts or 8
Re: New Layshafts?
Posted: Mon Mar 19, 2018 6:20 am
by garry inglis
There is a full kit with the wheel in a case for £350
Re: New Layshafts?
Posted: Mon Mar 19, 2018 9:09 am
by GTFOMWSC
you can't use the wheel as a spare for the front if you have a dbl disc set up but for any other you can
Re: New Layshafts?
Posted: Mon Mar 19, 2018 9:51 am
by GTFOMWSC
to add it can be used on the front with normal set up but you need to change the hub studs to their longer ones
Re: New Layshafts?
Posted: Mon Mar 19, 2018 4:18 pm
by corrado
rosscla wrote: ↑Sun Mar 18, 2018 11:43 pm
No it doesn't include the wheel but the FA Italia wheel is similar cost to a Sip tubeless rim. The wheels come with 4 plastic bungs for the holes you won't use if bolted to a standard hub.
There's also an 8 studded rear hub to suit standard layshafts, ie none splined.
Re: New Layshafts?
Posted: Wed May 23, 2018 8:51 pm
by Fux
I had an octipus kit fail.
Got a replacement and the hub was a completley different design. the first one was binding on the hub bearing. It might of been an early proto or something. I have no Idea.
The replacement kit is rock solid and layshaft is good quality and a lot beefier than innocenti design.
If you mark the splines/hub when you have found a position you can fit all 3 lock studs. its a doddle to take on and off as you don`t need a puller.
On a series 2 its a lot easier to change the tyre by removing the hub.
