Page 3 of 3
Re: Unsafe parts.
Posted: Tue Aug 15, 2017 10:28 pm
by fluff34567
Multi spline shouldn't come loose and rotate like that but I wonder about the wear marks half way along the hub splines .. is its the same setup as the other hubs with a specific hub cone?
Re: Unsafe parts.
Posted: Tue Aug 15, 2017 11:23 pm
by rosscla
Splined hub shouldn't need a cone - think Vespa rear hub though it has a surer way of preventing the nut coming loose. It's usually torqued to 55-65 lbft.
The recommended torque setting on a normal set up is 203NM or 150lbft but this is to compress the hub taper onto the cone.
Re: Unsafe parts.
Posted: Wed Aug 16, 2017 7:02 pm
by Fux
I have had great help from the dealer, actually picked up the phone and called me.
I have been missinformed on the torque value, and as some have pointed out its similar to a vespa and they reccomend the same value on this system.
New parts on the way, free of charge.
Like I said, Im pretty sold on the system and it felt rock solid and after speaking to the dealer I`m (and they) are convinced that this is what was wrong.
Re: Unsafe parts.
Posted: Thu Aug 17, 2017 5:09 pm
by fluff34567
So wasn't tight enough?
Re: Unsafe parts.
Posted: Fri Aug 18, 2017 2:24 pm
by Fux
I used 50nm, otherwise they were pretty baffeled as to why this would happen.
