Page 3 of 3
Re: 5 speed box fitting tips
Posted: Wed Aug 02, 2017 5:14 pm
by alanscottj
Think I ended up 20-47.
Works out final ration 4.57.
[/quote]
I think I ended up with 46x18 but I can't remember! Should of written it down :roll:
Posted: Thu Aug 03, 2017 7:04 pm
by Fux
Fellas,
I`m fitting my 2nd cyclone 5.
Did you use the little shim that fits between layshaft and bearing in the endplate?
also, damn the splines on the gear cluster have a realiy tight tolerance! I have to use a 3 pronged puller to get my LTH cluch off.
Posted: Thu Aug 03, 2017 11:45 pm
by Fux
Job done.
Piece of cake with the granturismo endplate and octipus layshaft.
Ended up with 1mm gear shim, no shim under the layshaft and no shim over the gear cluster.
Fingers crossed. haha
Posted: Sun Aug 06, 2017 12:50 am
by dirtyhandslopez
psychedelicropcircle wrote: ↑Mon Jul 31, 2017 1:30 pm ^thats the one I've just fitted was a little surprised the ribbed side didn't have oil slots in them, perhaps an expert might know as to why?
Not expert by any means, but I would think that if a groove is machined, the gear would be very thin where you machine the groove, making it weak..
