Re: Engine Nip!
Posted: Tue Jun 20, 2017 3:31 am
Coasting and clutching is a lot easier on the body than stopping and kicking
That's the way Dave Webster used to recommend. I've always run in my iron setups that way too. Always been spot on.drunkmunkey6969 wrote:Good advice. Lots of heat cycles, lots of short journeys, varying rev range, don't labour the engine.bristolmod wrote:I run in "short and hard"- on 4% semi synth.
Loads of short journey (3 miles max), using all the gears and giving it some "welly". Back home- let it cool and repeat. Up and down the box- don't be afraid to rev it. Don't leave it in one gear for too long, and don't let it labour on hills.
Works for me
Chris
k
Correct me if I am wrong but you have not had a rebore just new piston and rings. Are you sure the problem is running it in and not something else, air leak, jetting, different size piston to the last effecting piston to barrel clearance.Martin20 wrote:Evening all,
Running in my LIS150, after new piston and rings. Done around 60 miles, so far, nice and steady with no problems. Been out tonight and tackled a few longish hills which I guess put a little too much strain on the engine as it nipped up! I pulled in clutch, coasted for a 100 yards or so, let clutch out whilst in second gear and she started and got me the 4 miles or so home without further issues!
Question is, will I have done any damage, or can I just continue to 'run in' for another 100 miles or so?
All,advice/comments, appreciated.
Cheers
Martin
LI150 wrote:Correct me if I am wrong but you have not had a rebore just new piston and rings. Are you sure the problem is running it in and not something else, air leak, jetting, different size piston to the last effecting piston to barrel clearance.Martin20 wrote:Evening all,
Cheers
Martin
