Page 3 of 4
Re: Carb issues
Posted: Mon Aug 07, 2017 10:51 am
by dapper
Turn the petrol tap off just before you stop the engine. That will empty the float bowl a bit and stop it flooding when you come to start again.
Re: Carb issues
Posted: Tue Aug 08, 2017 4:34 am
by tippo88
I changed pilot jet to a 38 and then a 36. Runs much better and actually started after leaving for half an hour. See how it goes tonight. Fingers crossed !
Sent from my EVA-L19 using Tapatalk
Re: Carb issues
Posted: Wed Aug 09, 2017 8:20 am
by tippo88
Drove it for 30 mins.for the Malaysian equivalent of an mot and after stopping back to the old story of not starting and flooding . Frustrating to say the least.
Re: Carb issues
Posted: Wed Aug 09, 2017 8:51 am
by Chris in Margate
If you are 100% satisfied with the operation of the float and choke assembly, then maybe it's time to be looking elsewhere. Perhaps and only perhaps, having eliminated your carb there is another underlying issue.
1) Ignition spark is weak and just not strong enough to ignite a chamber full of fuel and after too many kicks, it floods.
2) Worn piston rings.
Shorten the gap on your spark plug and always kick with thottle shut. Try that.
Re: Carb issues
Posted: Wed Aug 09, 2017 11:51 am
by tippo88
Thanks will give spark plug a go that a go. It's a new rebuild so rings should be ok
Re: Carb issues
Posted: Thu Aug 10, 2017 10:21 am
by dapper
Check the tip of the float needle valve. If its a black tipped one change for a new red tipped one as they are resistant to ethanol in petrol.
Re: Carb issues
Posted: Sat Aug 12, 2017 10:51 am
by tippo88
Thanks dapper good advice will check.
Re: Carb issues
Posted: Sat Aug 12, 2017 12:43 pm
by mick1
Are you running a filter/bellows ? A lot of engines have problems with the fuel being trapped in the bellows, causing issues when hot starting.
Re: Carb issues
Posted: Sat Aug 12, 2017 12:48 pm
by tippo88
Am running bellows straight up to a foam filter. Will take a look. What's the option though don't really want to run open
Re: Carb issues
Posted: Sat Aug 12, 2017 6:10 pm
by Timbo
What filter are you using? If it's a breath sweet I have a rubber elbow with a hole drilled in the elbow for up right use which you can have/try.
