Page 3 of 3
Re: Engine Mount Removal Tool - Homemade
Posted: Sat Feb 18, 2017 8:40 pm
by gaz_powell
does the 100 quid include postage ???
Re: RE: Re: Engine Mount Removal Tool - Homemade
Posted: Sat Feb 18, 2017 9:46 pm
by fluff34567
gaz_powell wrote:does the 100 quid include postage ???
Posted: Mon Feb 20, 2017 11:00 pm
by gaz_powell
I can vouch for the one Corrado is selling - excellent quality and price (there are some shi#e ones out there)......be mad not to have one, even if you use only use it once.....
Although not as good as my NOS Innocenti one, hot footing from Italy as we speak!!!
Posted: Sun Mar 05, 2017 12:13 am
by fluff34567
The one from Corrado in use, had to fettle the gap edges ever so slightly but works perfectly... you need lots of heat into the casting and then the mounts wind out silky smooth.
Posted: Fri Mar 10, 2017 11:13 am
by corrado
Getting them out is the easy bit.
Keeping the new ones in line is the hard part.
Destructions can be found in the scooter centre Lambretta catalogue on page 95.
http://www.scooter-center.com/en/produc ... GE_KATALOG
Posted: Wed May 17, 2017 9:58 pm
by fluff34567
Tell me about it! I gave up after a while so will try it again tomorrow.
Posted: Thu May 18, 2017 11:20 am
by Adam_Winstone
I regularly find it beneficial to take a flat file to provide a better chamfer to the leading edge of the mount so that it finds its way into the lug ebetter and then aligns easier on its way through, rather than it repeatedly catching on the sharp edge and reaming its way through (loses interference fit if it does so).
Posted: Thu May 18, 2017 2:49 pm
by rosscla
Last set I fitted, after heating the casing, went in by hand
Posted: Thu May 18, 2017 3:03 pm
by corrado
Adam_Winstone wrote:I regularly find it beneficial to take a flat file to provide a better chamfer to the leading edge of the mount so that it finds its way into the lug ebetter and then aligns easier on its way through, rather than it repeatedly catching on the sharp edge and reaming its way through (loses interference fit if it does so).
Yes, the UNI ones have a good chamfer on them and went in much easier than others I've used.
Anyone tried the new "softer" Scootopia ones yet?
Posted: Thu May 18, 2017 6:44 pm
by fluff34567
Must have had a bad day yesterday as the new ones went in easily 2nd time around.
