Page 3 of 7
Re: TV175 1963 strip and rebuild
Posted: Wed Dec 28, 2016 6:34 am
by garry inglis
Love the clutch compresser you won't fit that in your toolbox lol
Posted: Wed Dec 28, 2016 11:55 am
by gaz_powell
Wow, some great equipment available.....perfectly placed for this type of work!
Posted: Wed Dec 28, 2016 11:25 pm
by fluff34567
The 2 marks are cracks! confirmed by dye penetrant.
At the moment I'm having huge difficulty removing the lower steering bearing race. I might have to cut a slot in it
Gearbox stripped , good too as all nuts were very loose.. imagine the absolute slightest pinch up with a 1/4 ratchet.
I noticed something today on the forks... the weld on cable loop, I have 2 welded loops ut have only seen them with 1 welded loop and 1 bolt on loop... any ideas?
Posted: Thu Dec 29, 2016 8:40 am
by fluff34567
Sorry.. due to the edit time out I couldn't add the last bit.
Any ideas when they changed from 2 weld on loops to a single weld on and bolt on? I have found quite a few photos of the 2 welded loop forks.
Posted: Thu Dec 29, 2016 9:48 am
by holty
if your gearbox endplate nuts were loose, check to see if the locating dowels have worn the case, they often do, mine had done so i fitted the endplate without the dowels then drilled trough the endplate and into the case with an 8mm drill then made 2 new dowels in that size, its a tight fit now.
Posted: Thu Dec 29, 2016 10:44 am
by Adam_Winstone
Not sure when they changed from weld on to 1 weld + bolt on but it is not uncommon for early SIII to have both weld on.
Posted: Thu Dec 29, 2016 11:01 am
by firekdp
fluff34567 wrote:Sorry.. due to the edit time out I couldn't add the last bit.
I believe it was around December 1963. Same time as the panels changed.
Posted: Thu Dec 29, 2016 11:15 am
by fluff34567
Thanks for the replies above..GREATLY appreciated! I didn't notice any wear but will have a closer look.
Posted: Thu Dec 29, 2016 12:09 pm
by garry inglis
holty wrote:if your gearbox endplate nuts were loose, check to see if the locating dowels have worn the case, they often do, mine had done so i fitted the endplate without the dowels then drilled trough the endplate and into the case with an 8mm drill then made 2 new dowels in that size, its a tight fit now.
thats got to be tip of the day holty nice one
Posted: Thu Dec 29, 2016 7:13 pm
by fluff34567
Not a good day I am afraid... couldn't get the flywheel off the crank regardless of which puller was used inc a rather large 3 legged version in addition to the "proper" one and rediculous amounts of heat etc.
I had to sacrifice the crank... this is what's left of the flywheel taper.
